diyAudio Sponsor
Old 17th June 2009, 09:05 AM   #1
hungmao is offline hungmao  Hong Kong
Default Value of Resistors of EL34
Hi Bros,
I am green in DIY. Recently, I have add a CLC filter to high voltage power supply of my EL34 power amp. As I know, there is an internal resistance for the choke and which makes the voltage drops.
In attachmented picture, the red text is the intented voltages of design. But after applied the CLC filter, the voltages dropped to the values in green color. Could any bros teach me how to calculate the values of R1 and R2 in order to raise the dropped voltages to the intended voltages.
Thanks a lot!
Eric.
Old 17th June 2009, 09:56 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I don't see any picture?
Should be a pretty negligible drop though.
Old 17th June 2009, 03:13 PM   #3
I'm so sorry that the previous attachment may has sth wrong.
Pls refer to the following image.
Thanks all for your kindly help.
http://i104.photobucket.com/albums/m...06/DZ_EL34.jpg
Old 19th June 2009, 01:42 AM   #4
could any one help?
Old 19th June 2009, 02:38 AM   #5
Ty_Bower's Avatar
All you need to know is V = I * R.
For example, the case of R1:
Original case:
Voltage across R1 = (376 - 314) = 62 volts
Current through R1 = 62 volts / 5.1K ohms = 12.15 milliamps
New case:
Voltage across R1 = (352 - 314) = 38 volts
Current through R1 = 12.15 milllamps (from above)
new value of R1 should be 38 volts / 12.15 mA = 3.125 kOhms
Hope this helps. Of course, you will not be able to correct the reduced B+ supplied to the output tubes. Also be aware that as you change the current drawn by the driver tubes, the 352 volts seen at the end of the new choke should increase slightly. This will throw off your calculations a little bit.
Good luck!
Old 19th June 2009, 03:05 PM   #6
Thank you very much Ty_Bower, i got it!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
El34 Se Jean-Paul_2 Tubes / Valves 2 11th June 2009 05:33 PM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
Weird Resistors, anyone know anything about resistors priscared Parts 1 19th March 2004 11:59 AM
Page generated in 0.13639 seconds (48.78% PHP - 51.22% MySQL) with 12 queries
