Speaker sounds blown...but isn't
Old 16th June 2009, 03:44 PM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Perhaps you have a bad OPT and have DC on the speakers?
Old 16th June 2009, 04:18 PM   #12
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Such rattle sound may indicate oscillations on high frequencies caused by mods.
The Devil is not so terrible as his math model is!
Old 16th June 2009, 10:05 PM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default Re: Speaker sounds blown...but isn't
Originally posted by bereanbill
I recently aquired a Danelectro DM-10 guitar amp whose speaker had a dropped voice coil. I replaced it with a known good speaker and it still had that "rattle" that is indicative of a voice coil rubbing. I tried 3 different speakers, incuding a new Jensen with the same result. All of these speakers sound fine in other amps...any ideas?
Is the speaker cone fouling the cabinet somewhere ?
Otherwise sounds like an amplifier problem.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 17th June 2009, 04:25 AM   #14
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
I was experimenting with my amp and my amp was in a state where layout was pretty sloppy. I heard sounds similar to what you are describing at higher volumes. I confirmed with a scope that the amp was breaking into oscillation every time the amp clipped but would stop when the amp recovered from clipping. Looked wierd on the scope. Sounded exactly like what you are describing.
Cleaning up the layout (making leads very short) cured the problem.
Old 17th June 2009, 01:49 PM   #15
flysig is offline flysig  United States
Is the speaker baffle warped? If it is, the speaker frame could be getting twisted/warped when you attach it, causing the voice coil to rub.
I'd guess the other suggestions are more likely than this, but thought I'd toss this possibility out there, too.
Old 17th June 2009, 04:22 PM   #16
bereanbill is offline bereanbill  United States
Hey...SS..that is the most cohesive reply yet!!! I'll give it a shot. Seems wierd that Danelectro wouldn't bypass the cathodes on this am p when most others are. Maybe a lead dress issue??? THX
Old 17th June 2009, 04:29 PM   #17
jjman is offline jjman  United States
I would try it with the speaker wired but NOT mounted in the cab.
If it still makes the noise and the speaker is good, it's probably the oscillation mentioned. That happened to me when I removed the "anti-oscillation" cap from my '74 Fender Vibro Champ. (The cap also can reduce some high end.) So I changed the grid wire on that tube to a shielded one and the oscillation was cured.
Speaker sounds blown...but isn'tHide this!Advertise here!
irritating sounds from speaker maxicarb Car Audio 8 20th August 2007 12:16 AM
Speaker problem - sounds muffled wixy Full Range 6 5th September 2006 10:59 PM
Blown speaker (coil?) anything I can do? aletheian Multi-Way 7 4th December 2005 10:54 PM
blown speaker in a quadbox tivruski Multi-Way 0 4th November 2005 10:11 AM
My NSB sewer speaker sounds like a 2" bose MPM Full Range 23 6th January 2005 05:36 PM
Copyright ©1999-2017 diyAudio
