| diyAudio Sponsor | ||
I have an S-5 electrons K-16LS with the tone control board and its been working great as the amp for my computer speakers for some time, but yesterday one of my monitors fell on it. There seems to be no obvious damage (no broken tubes, caps anything else) but now there is static noise coming from the left channel.
the noise is independent of volume control, and stays at constant volume. I've been reading a lot of tube amp theory books, but I'm still pretty new to tubes. Is this what happens when a tube becomes gassy, and there is a small crack I'm not seeing? If so, are there some simple ways to test which tube is bad (pulling and swapping around?) or could there be another explanation and some other tests i can do to track down the problem. Thanks for the input Josh Hill |
#2 |
Check your circuit traces, it could be that you have cracked one and have poor or intermittent contact. I would also check your solder joins, could be one has popped off the board.
#3 |
I checked the traces and solder joints and found no problems. Then I started pulling out pairs of the power tubes and the noise was still there. Found out it was one of the 5670's by swapping it with the other channel.
| Static noise from new system | 79corona | Car Audio | 1 | 5th September 2007 08:53 PM |
| B&O Turntable static noise Please help! | danioh | Analogue Source | 2 | 11th April 2007 07:29 PM |
| static noise question | kambrian | Car Audio | 2 | 15th July 2005 11:59 PM |
| static noise and hum | Edwin Dorre | Pass Labs | 17 | 20th June 2002 07:47 AM |
| Removing static noise from stereo. | Trist | Everything Else | 2 | 7th June 2002 05:57 PM |
| Page generated in 0.14930 seconds (35.30% PHP - 64.70% MySQL) with 10 queries |
