| diyAudio Sponsor | ||
829 B is a dual tetrode with a shared cathode. I know that in the past people have parallelled the two halves and converted the whole thing into a triode for SE use.
Pondering... If you strapped it in triode on both sides, could it successfully work as a diff amp stage such as a common cathode phase splitter or an LTP? Does it have any particular characterisitics that would make it unsiutable for this purpose? Has anyone done this? I have 4 NOS RCA 829B's sitting here under my desk and I'm wondering what use I could put them to... |
#2 |
in the interests of Closer Economic Relations, and in defference to the ANZAC brotherhood, you should send them to your poor cousins in NZ. PM me for my delivery address...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
as I recall, they have a spectacularly low rating on the G2 which makes U/L problematic, but I always thought they would be a sitter for the "Compact" treatment. IIRC they have a reasonably easy drive requirement, so you could conceivably get a 10-12wpc pp stereo unit from three tubes - a dual triode voltage amp and two 829B outputs. Leaves you two spare 829B tubes for later when they start getting tired! Or you can send them to me...
#4 |
you're not set up for PM or email at present...
#5 |
no wonder I hadn't received any of the free-bees I've been soliciting!
#6 |
The screen is common between sections, so you can't triode strap each section independently.
#7 |
to both sections, as is the cathode. Still, in pentode you can get PLENTY of watts out and still only need 36V pp to drive it. Triode is out though. here's a design - can't vouch for its quality however.
#8 |
hey-Hey!!!,
There is also a g2-cathode internal capacitor. Rigging that one as triode requires a means to deal with substantial grid-plate capacitance. Now if you can do a LTP in pentode mode, that tube is a fine option. Type 832 as well... cheers, Douglas
the Tnuctipun will return |
#9 |
Since you are forced to use these in Pentode mode, then you should go look at Gary Pimms Tabor amp for inspiration. This design allows triode levels of output impedance with Pentode power, and all with local feedback. The sound is very neutral and has nothing of the pentode nastyness. Think of driving it with a pentode LTP for best results. The DC coupling is tricky to get right so I advise dropping it in favor of coupling caps.
Shoog |
#10 |
As Colt noted, the screens are shared. But you could still run it as a pentode LTP instead. Just for novelty?
| 829B Based Amp | silverchris | Tubes / Valves | 11 | 12th March 2012 10:26 AM |
| 829B SE Comments???? | coldcathode | Tubes / Valves | 51 | 12th February 2010 04:08 PM |
| rca 829b bias ? Audioromy 828 | oleslot | Tubes / Valves | 3 | 14th April 2009 02:13 PM |
| Page generated in 0.14736 seconds (57.30% PHP - 42.70% MySQL) with 10 queries |
