| diyAudio Sponsor | ||
It seems there are quite a few people who have built the Aikido line stage using the 6n1p and 6n6p tubes but I'm still having trouble finding the values for the requisite resistors n such. Also wondering if the Aikido might just be better off using the 6n6p in both input and output stages (as some have suggested). This is my first tube project, I figured it would be a relaxing project for down time but it has already given me a couple of restless nights. Thanks in advance!
#2 |
The 6N1P values were printed in the original users guide. If you will give me your B+ voltage I can give you the values.
I don't have anything for the other tube. |
#3 |
You can use the same values as for ECC99 or 5687.
David |
#4 |
My B+ should be about 250v, thanks for the help.
| 6N6P in an Aikido? | Original Burnedfingers | Tubes / Valves | 29 | 20th January 2009 08:14 PM |
| 6n1 tube = 6n1p | Jcartella | Tubes / Valves | 2 | 24th September 2007 04:00 AM |
| 6n1p Screen | matthew2456 | Tubes / Valves | 1 | 22nd January 2007 05:01 PM |
| 6n1p (6922/ecc88) Nos | Mayday | Swap Meet | 0 | 2nd January 2007 12:14 AM |
| Is 6N1P = 6N7 = ECC31 | ddriveman | Tubes / Valves | 1 | 18th March 2004 01:09 PM |
| Page generated in 0.18058 seconds (32.44% PHP - 67.56% MySQL) with 10 queries |
