diyAudio Sponsor
Old 15th June 2009, 02:40 AM   #1
Default Power switch location..
I'm working on a build of Steve Bench's RIAA5 using salas's shunt reg. I'm planning on putting the power supply in a separate enclosure which will be out of sight (and maybe difficult to reach. It would be nice to have the on/off switch on the main unit. Is there a safe way to do that? Lifting the ground for the power supply would shut off the preamp but the power supply wouldn't really be off, would it? Or what about a relay in the power supply to disconnect the PT primary? As long as it could handle the current and defaulted to open rather than closed that should be ok, right? Means an extra conductor in the cable from PSU box to pre box but that's not a big thing.
Old 16th June 2009, 03:44 AM   #2
boywonder's Avatar
A relay in the PS module is convenient, also allowing low voltage up to the switch if desired, but you need some "always on" voltage in the PS (for the relay coil) so that when you flip the switch the relay is energized and closes the mains for power-up.
Old 16th June 2009, 03:59 AM   #3
Send a message via AIM to DigitalJunkie
A small 'wall-wart' might suffice for a small stand-by supply for the relay. (Even that would be overkill,for just a relay.)
Maybe you could find a small PCB mount power trans.
Old 16th June 2009, 04:38 AM   #4
Rob11966's Avatar
Hi Boxerboxer,
I have done this with all of my amps. I use a small 9v PCB power transformer and rectify the 9v supply with a simple bridge rectifier and capacitor arrangement. This provides the 12v (or thereabouts) for the relay coil and any LED's/lamps you need to power.
As far as the relay goes, I use a 3A solid state optical relay to power the power transformers (like this one -http://www.jaycar.com.au/productView.asp?ID=SY4080&keywords=relay&form=KEYW ORD). It's a good arrangement. It allows the use of a wide variety of low voltage switches to be used and also avoids running the 240 ac to the front of the amp.
Rob
Thermistor Location for F5 power supply calvinhpk Pass Labs 37 10th April 2012 05:53 PM
Location of voltage-dropping power resistor hollowman Power Supplies 21 5th December 2008 08:13 PM
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 01:54 PM
Power supply component location. HenryM Chip Amps 0 20th January 2005 05:53 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.09866 seconds (60.41% PHP - 39.59% MySQL) with 10 queries
