| diyAudio Sponsor | ||
HI,
I was thinking yesterday about simplifying my quad 33, and then realised that the output level was only 0.5V for full amplifier output. I then thought it could be a good idea only to have a minimalist preamp, with unity gain, only to adapt the impedance ( quad 303 input impedance is quoted as 22K and 33 output impedance is 1K). so I was thinking, would a simple circuit with a potentiometer and a simple classic cathode follower be a good idea of realisation? would it work well ? I'd be happy to have some advices. Hugues. |
#2 |
It will work very well as long as the cathode follower is designed competently. I published a circuit like this here and on my website- you don't have to do the full-blown circuit, but there are some basic design hints in the article which will (I hope) help you avoid the most common mistakes.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Hugues,
You want to use a high gm type, for a low O/P impedance. The current production JJ ECC99 is very well suited to this job. IB should be substantial, as charging and discharging the interconnect cable capacitance is not problematic. A bipolar PSU allows you to avoid a cap. in the I/P circuitry. The 10M45S "chip" will allow you to CCS load the CF, with very little muss or fuss. CCS loaded CFs yield superior performance.
Eli D. |
#4 |
thanks for the answers.
so, I'd like to start on a simple cathode follower with single psu. I've seen some vintge circuits with ecc82 cathode follower but don't know if this could be useful as tube amps have usually higher Z imput thant solid state... so I'm looking for a simple circuit if anybody can help me ( the 2 capacitors, 5 resistors kind) but well calculated, as I've read many times that poorly conceived cathode followers gave very poor results... thanks for your help ! Hugues. |
#5 |
Hello there, My first system was a 33/303/Fm3 Circa 1997
Have you surfed through the net and discovered the Quad improvent site ? I used to own a set of 303 amps , that i ran as Bi amped , one amp per speaker, just using a tweaked 33 pre ( i added a seperate on off button and fitted a 50k noble vol pot ) Big difference..didn't need to change much more after that. I then changed the main power supply caps in the 303 . I had a valve FM3 tuner. I think that was the best sounding radio for a long time..until all the stations here went compressed ..sorry to ramble... Have you tried any other amp combination yet , as the old 303 can sound a bit soft . There's no doubt about it's build quality..bomb proof... I have since that first system had the upgrade bug ... sold the quad stuff , tried a couple of amps and have now built my own system using kits...and im now very satisfied..all transistor..as house isn't suited to valve ..small children ! |
#6 | |
actually, I'm very satisfied with my system. I just thought that the signal goes through a lot of useless components through the quad 33 ( too much gain, eq control etc...) so I was thinking of a minimalist preamp, more to be seen as an experiment. and I'm on holiday now, so I thought this would be nice to do it now. so I found this circuit in a morgan jones book with an e88cc, and I happen to have a spare 6922 jan philips. what do you think of that schematic? should it be working alright? any comments welcomed ! Hugues. |
#8 |
hi,
here is the circuit i'm gonna try. I'm reusing a transformer I already have... I'm not sure about the value of the volume pot, 47K or 100K? Thanks for your help, Hugues. |
| Swap Shanling CD-T80 valve CD player for Quad valve equiment | johnm | Swap Meet | 2 | 24th September 2009 12:15 PM |
| WTB QUAD, DIY LD valve amp, JX92 | Coyote | Swap Meet | 0 | 31st July 2009 10:14 PM |
| Big valve preamp | beamnet | Tubes / Valves | 20 | 27th May 2007 11:14 PM |
| valve preamp | damianl | Tubes / Valves | 4 | 7th July 2006 08:42 AM |
| Quad 22 Valve Amps | WARREN | Tubes / Valves | 9 | 11th September 2004 10:39 AM |
| Page generated in 0.18475 seconds (57.61% PHP - 42.39% MySQL) with 11 queries |
