diyAudio Sponsor
Old 14th June 2009, 02:17 PM   #1
korneluk's Avatar
Default Paging Wavebourn - article on Russian caps...
Wavebourn,
I am hoping there is some useful info contained in this article. Could you help with a translation?
http://www.magictubes.ru/ves/kondens.htm
TIA,
-- jose k.
Old 14th June 2009, 04:05 PM   #2
Goto http://www.translate.ru and translate the web page. You'll get the gist of it, though it won't translate the scanned tables.
Basically, it is just some random guy taste testing various caps. No profound conclusions. It depends on the circuit, specs don't tell the whole story, you can get good performance with Russian caps, etc.
-e
Russian PIO caps. Should I use them? G Tubes / Valves 70 24th May 2012 12:07 PM
WTB: (4) .1uf/400V+ K40 Russian PIO Caps mrdon Swap Meet 0 27th August 2008 03:23 AM
article in NY Times on Russian tubes mlost Tubes / Valves 1 16th May 2006 02:27 PM
russian teflon caps costiss Parts 3 25th November 2004 01:19 PM
Russian oil caps ? Tomatito Tubes / Valves 38 20th July 2003 12:57 AM
Page generated in 0.07726 seconds (54.93% PHP - 45.07% MySQL) with 10 queries
