| diyAudio Sponsor | ||
I was pondering my old S-5 electronics k-12 tube amp kit and I decided that I want to actually get some use out of it. I have been using headphones primarily because of my housing situation and I think it is time for a headphone amp. So, my idea was (in the name of a very low budget) that I use the parts I have from that old amp (a power trans, a few 10GV8's, and some push-pull opts, etc) and build a new one with a whole new circuit. I would just discard the PCB for point to point and use new resistors, caps, and sockets. Now, I am a circuit noob so I hope that there may be someone out there who could help me design a headphone amp using the 10GV8 and the kits iron. I was thinking maybe Single Ended? Would I even have to use those opts?
Any thoughts would be extremely appreciated, ((AE))
((AE)) |
#2 |
((AE)) |
#3 |
I know 10GV8 is not considered the top tube for audio but there must be some way to rig it for a low power application like this....
((AE)) |
#4 |
You can use this amplifier to drive your headphones. Use a voltage divider connected across the amplifier's speaker output comprising an 8 ohm resistor in series with a 1 ohm and connect the headphones across the 1 ohm resistor. (The 1 ohm is grounded at one end and this point will be common to both channels to provide the ground connection to the headphone jack.)
You may have excessive hum depending on how noisy that amplifier actually is and you may need to tweak the resistor values to get enough attenuation for the headphones you are using. There are a lot of otl headphone amplifier designs over at headfi and I would take a look at building one of those instead - saving this amplifier for the day when you can use it with speakers again.
www.kta-hifi.net |
#5 |
Thanks a bunch for the reply!
Voltage divider, makes sense. But I can't visualize this on paper- could someone draw me a schematic?
((AE)) |
#6 |
http://www.ecpaudio.com |
#7 |
Thanks a lot man, I will see how this sounds with my Senn HD 530 II's. Now I can move on to bigger and better things. I am thinking of starting a SE EL34 project so that once I move I can rock the house!
((AE)) |
| X0.2 Preamp advice & circuit | Barry1 | Pass Labs | 19 | 2nd June 2011 01:46 PM |
| Newb looking for some expert advice for his first project (5.1 speakers) | tim_programmer | Multi-Way | 3 | 19th July 2008 05:42 AM |
| Major Issues With Building The BPA200 Reference Servo Circuit! | MartyM | Chip Amps | 9 | 8th March 2008 10:50 PM |
| I need some eq. hook up expert advice please! | graykeene | Tubes / Valves | 0 | 11th July 2007 08:44 PM |
| Page generated in 0.10927 seconds (67.09% PHP - 32.91% MySQL) with 11 queries |
