| diyAudio Sponsor | ||
This may be a dumb question, but if I'm using a choke that's rated at 150mA at 600VDC, can I uprate the amperage if the voltage I'm using on the power supply is significantly less, say 400VDC?
Thanks for any help.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
#2 |
No, the current rating of a choke is normally determined by the point (current) that causes the choke to saturate beyond some percent (maybe, 80) of nominal. I^2R also needs to be considered.
#3 |
Thank you for the quick reply, sir.
| Choke question | JoshK | Tubes / Valves | 5 | 1st December 2008 03:31 PM |
| Choke question | nkg | Tubes / Valves | 26 | 22nd November 2006 08:39 PM |
| 20W PP Choke PSU Question | sorenj07 | Tubes / Valves | 0 | 29th July 2006 05:57 PM |
| Toroid choke question | okkyn | Tubes / Valves | 3 | 24th December 2005 05:26 AM |
| choke and cap question | Raj1 | Tubes / Valves | 2 | 2nd November 2003 02:30 PM |
| Page generated in 0.17730 seconds (31.70% PHP - 68.30% MySQL) with 10 queries |
