| diyAudio Sponsor | ||
I have some questions to the guys here I wish to build a new Tube Pre and was looking at various options and designs, I have almost shortlisted the circuit below and need some opinions on that !! Also if someone has a better circuit (either hybrid or otherwise) please post it here so that I can try to use it !! Also I have some doubts,Although it seems like a foolish one's but I still have them none the less and want to clear it !! 1) The Current ratings on the tube is not much,but is 50MA sufficient for stereo circuit ? 2) The Heater Current is 300MA according to the datasheet,will it constantly draw that much ? will a 500MA rated trafo work for both the channels (Stereo ) ?? 3) I plan to use a Silver plated PCB as opposed to a P2P wiring,So although die hard fans will say no I want to just get a opinion as how bad this can be ?? This is all I can think of as of now Please do share your thoughts and idea's and help me out Regards.
SoundsGreat! |
#2 |
Oops forgot the pic !! Here's the one !!
SoundsGreat! |
#3 |
highs will fall off pretty fast with much cable, such a high impedance output. You won't be able to drive anything SS with it, either.
nor do i see the need for feedback.. or why the first tube is run so cold... as for heater, yes it's constant, so 600mA would be pushing it. |
#5 | ||||
Many thanks for the reply !! I have few doubts and hope you don't mind answering them ! Quote:
How will it pushing ?? what I mean is for 2 channels is 500MA ( taking 250MA per tube and per channel ) ? or will a 650MA be sufficient (taking 325MA per Tube/Channel with 25MA as reserve or taking deficiency of the overall PSU in mind ) ? Sorry if I sound silly,I have many years of experience in SS but this is not something I tried before ! so this is uncharted waters for me !! Finally if you as said before have a better circuit then I'd be the most happiest person to try it !! Regards.
SoundsGreat! |
#6 |
A simple SRPP stage might be a good choice. High input impedance and low output impedance.
Frank |
#7 |
Start by defining what you want the preamp to do. Hifi or MI? Sources? Loads? Desired gain? Distortion and noise target? Then it will be much easier to select and critique a design.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
1)Its supposed to drive a SS Power Amp ( Nmos and its varites By Quasi,but not limited to it ) 2) Precision and Accuracy in Sound, Audiophile ?? 3) Normal Gain that one would expect ! 4) Distortion and Noise,well whats good here will leave to you guys !! On more general note, Am sucker for details (will dig any depth to find in the music) and mostly like a Neutral sound (with a small exception of tube colouring ) ! Hope this is enough for some replies now ! else please do ask ! Again I mention here that Am not well versed with Tubes as Am with SS ! so any deficiency in answering the question you guys throw at me should be excusable Regards.
SoundsGreat! |
#9 |
If this is a line amplifier, ie post volume control as drawn, it will have too much gain with a 12ax7 up front. The output is not buffered so you can't drive a solid state amplifer with such a high output impedance right off the plate of the second tube. Most solid state amplifiers if it's BJT (bipolar junction transistor) have an input impedance of around 5K ohm. If the power amp has a jfet input stage then the input impedance is more infinite (=1M ohm). But you still won't be able to drive a cable longer than a few inches with this set up. The cable capacitance will roll off the frequency response. You want a low output impedance (=150 ohm) of a preamp feeding a high or infinite input impedance (at least 20 times higher) in the power amp. Look at Jones book especially the mu follower and the Beta follower. A mu follower has two outputs of different impedances. And choose a lower mu tube like a 6SN7GTB or a 6J5GT. GRH
"The gift of imagination is the gift of the gods imparted to a few for which they receive innumerable kicks in the a$$ their entire life." Le Corbusier (Edward Jenneret) |
#10 | |
** Yes the heater runs all the time and does draw full current. It works just like a light bulb. To power to 300ma heaters You need at least 600ma but then you want a small margin so I'd say But you may need more tubes depending on what you need to do in terms of inputs and outputs ** A PCB can be better than point to point wire, could be worse. It all depends of the skill of the engineer would worked out the laayout and design of each. The good thing about PCB is that if you have a good design you can mass produce it and all units will be the same. Either method can be very good. However.... For one off audio work turrent boards workl well because they make the ciruit very easy to modify. And you WILL need to tweek and modify it. So I'd suggest a third option, turrets for a custom design. And yes you WIL be tweeking this. Th "AX" tube may have more gain than you want. For example I'm using your schematic (more or less) in a guitar amp I'm building where I want the preamp driven to high levels of distortion. You may not want so much gain and my go with a AU, AT or AY tube. But it's easy to swap this stuff around |
| UK Law query | john blackburn | The Lounge | 35 | 15th May 2009 09:59 AM |
| query | Professor smith | Multi-Way | 2 | 5th May 2009 01:47 AM |
| ECC83/12AX7 Tube test query | waam68 | Tubes / Valves | 8 | 8th November 2007 07:52 PM |
| Possibility query: MyRef + Tube? | eVITAERC | Chip Amps | 31 | 2nd July 2007 01:57 PM |
| Mullard Made Tube Source Query | Eli Duttman | Tubes / Valves | 5 | 3rd December 2006 04:23 PM |
| Page generated in 0.22704 seconds (50.08% PHP - 49.92% MySQL) with 11 queries |
