| diyAudio Sponsor | ||
I am evaluating James 6123HS for my amplifier, but I could not find parameters. For example, primary inductance, iron core grade, primary resistance, etc. All I could find was Wattage, size, weight, etc. More parameter is better. However, I could not find those on-line. I did not even find the manufacturer's web site. Can somebody help me? Thank you!
#2 |
| Using James JS-6123HS with EL84 SE is overkilled? | nina | Tubes / Valves | 2 | 18th May 2009 05:04 PM |
| james 6123hs | totaltech | Tubes / Valves | 4 | 29th August 2008 11:21 PM |
| WTB - James 6123HS Transformers... | Guiness | Swap Meet | 0 | 10th June 2008 10:44 PM |
| Fun with James | Nixie | The Lounge | 2 | 1st March 2007 06:13 PM |
| Max 300B SE output possible with James 6123HS ? | ashok | Tubes / Valves | 4 | 17th June 2006 02:07 AM |
| Page generated in 0.15178 seconds (38.85% PHP - 61.15% MySQL) with 10 queries |
