| diyAudio Sponsor | ||
Hello DIY Audio! its been a while...
I took my El34 SE amp, and converted it to a fixed bias, in all honesty, I didn't look back once I changed it. The Thing just flat out sounds better. My EL34s are now getting to be 4 years old (its hard to believe its been that long). In that time, the abuse they have taken has been more than admirable, so I am deciding to retire them. I was thinking of getting a Pair of EH EL34s, and I was wondering if it was okay to adjust their bias voltage while the amplifier was on. whats the worst that could happen? The bias circuitry is a UF4007 run into a rather large cap, and a voltage divider with a pot, if that makes a difference... -Moose |
#2 |
yes you can, as a precaution, make sure the pot is turned way down, ie. as negative as you can make it.
Do you have a small resistor in the cathode cct? if you do, monitor the voltage across it to set the current as required. |
#3 | |
Sheldon |
#4 |
Yep, there is a Resistor in there, I didn't think to start with the Voltage Really negative though, good idea
Thank you |
#5 | |
Anyway, you probably don't need to crank bias all the way down. I'd say that you are probably safe if you back it off so that you get about 50-70% of the target bias current with the tubes you have in place. That should give you a safe starting point for a new set. Nice thing about tubes is that they can tolerate brief periods moderately in excess of dissipation ratings, without damage. Sheldon |
#6 |
On bias supplies, a very good hint to avoid disaster when perhaps the pot gets old and the slider 'disconnects'. Have a resistor (could be fairly high value) connected from the pot slider to the negative side of the bias supply, That way, should the pot slider connection to the track become suspect, one does not run the risk of sitting with an 'open' grid perhaps going positive and causing over-current.
I am not the originator of this; as far as I know KevinKR proposed it some time ago. (If I am crediting the wrong person, kindly advise!) |
#7 |
diyAudio Moderator Emeritus
Johan is right. Pots can fail and you need a fail-safe backup that will send the grid negative. I've seen really dumb examples of a 'fail-safe' path to ground instead of the negative supply.
#8 | |
Sheldon The bottom schematic here is not exactly the same, but shows the same principle: http://www.people.cornell.edu/pages/...switching.html |
#9 | ||
Hey guys
#10 | |
Sheldon |
| Fixed bias vs. auto bias | HFGuy | Tubes / Valves | 30 | 14th October 2011 09:45 AM |
| Finding bias point in PP fixed bias | beamnet | Tubes / Valves | 14 | 7th December 2008 01:25 PM |
| BOZ bias adjustment help | rtate | Pass Labs | 16 | 11th July 2008 07:04 PM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Self Bias and Fixed Bias for Big Tubes? | commstech | Tubes / Valves | 12 | 24th November 2006 02:17 PM |
| Page generated in 11.00408 seconds (0.94% PHP - 99.06% MySQL) with 10 queries |
