diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   110v or 220v, how can you tell? (http://www.diyaudio.com/forums/tubes-valves/145490-110v-220v-tell.html)
fjmart134 8th June 2009 02:10 PM
First off I am a newbie to tubes and electronics, so please forgive me for asking a stupid question... Got hooked a couple months back when I built a k-16ls kit, and decided I wanted more and bought a Chinese 6p3p tube amp from e-fay for about $250. I plugged it in and I can get barely any sound out of it. The vendor said it is set for 110, but I am thinking it was built for 220v.
So my questions are:
1. With out a schematic, how can you tell if the amplifer was made for for 110v for 220v.
2. Is there somewhere on the transformer I can take a measurement to find out what it was designed for.
Many Thanks,
fjmart134
whitelabrat 8th June 2009 02:26 PM
An easy test would be to clip your multimeter leads on the heaters of one of the tubes. If the primaries of the power transformer are indeed 220v you will read half the appropriate heater voltage on your meter. I would also suggest avoiding performing any tests without the tubes installed where you may over voltage the power supply capacitors.
Of course use the appropriate safety precautions before turning any power on.
Richard Ellis 8th June 2009 10:18 PM
2 Attachment(s)
Is this your unit???
If it is, the specs say it is 220VAC only.
____________________________________________Rick.. ....
Resources saved on this page: MySQL 18.75%
