I'm building a pre-amp with 5965 tubes. I have some output transformers that I believe were built for 5687s. I have no way to test the trans to know.
Since the plate resistance of a 5965 is ~7000 and the 5687 is ~3000 what will that translate to sonically if I put a 5687 optimized OT on a 5965? At the moment I have the circuit optimized where everything is sounding beautiful save for issues in dynamics such at impact, speed, attack and weight. I'm wondering if I'm fighting the OTs? |
| Tubes load resistance and output trans impedance | Jeffy74 | Tubes / Valves | 4 | 22nd December 2012 08:53 PM |
| Question regarding to output power trans | hc167 | Solid State | 14 | 28th June 2008 09:41 AM |
| Plate load resistor question | Carlp | Tubes / Valves | 14 | 21st January 2008 01:41 PM |
| plate load ccs ala gary p question | lt_texan | Tubes / Valves | 1 | 31st May 2007 04:32 PM |
| Noob question about plate load | eforer | Tubes / Valves | 14 | 23rd May 2006 05:24 AM |
