Help on EL84 / ecc83 SE project -very low volume - Page 2 - diyAudio
Old 6th June 2009, 01:03 PM   #11
mcgaag is offline mcgaag  Netherlands
He Erik,
Thats it, i put in the wrong value. 220 instead of 220k. I have to go now so i am going to change is tonight.
Thank a lot, i will let you know how it turns out.
Rob
Old 6th June 2009, 03:31 PM   #12
Hi Rob
Glad you found it out that fast! I am almost sure that once you change that resistor you will have music: I hope you have some in stock, so you can still listen to the amp this weekend!
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 6th June 2009, 05:42 PM   #13
Yep, there is music now! Thanks Erik pointing me in the right direction. Learned a lot building this amp.
Now the next challenge. Remove a nasty hum.
I will post a picture of my 1st diy tube amp!
Thanks for thoughts everyone.
Rob
Old 6th June 2009, 07:22 PM   #14
It sounds nice except for that nasty hum. If i remove the tubes the hum is gone. Does this mean the tubes are broken?
Old 6th June 2009, 08:09 PM   #15
After reading some stuff i don't think its hum but buzz i hear...
Old 6th June 2009, 08:15 PM   #16
Alastair E's Avatar
Not necessarily...
try elevating the heaters to +40-50 volts with refrence to chassis, Use simple two-resistor pot.divider from +b to chassis, and de-couple with summit like a 0.22uF cap....
That should remove the heater-bourne hum often found in gain-stages like that shown...
Das Beste Oder Nichts
Old 6th June 2009, 08:43 PM   #17
I don't think the buzz comes from the heaters. If i remove the heater power when the amp is buzzing the buzz is still there.
By the way, i did not rectify the heater power so it is AC.
Old 6th June 2009, 09:23 PM   #18
nigelwright7557's Avatar
I have spent many happy hours trying to fix hum problems.
Running heater wires near inputs is bad.
Good decoupling is vital or the hum on the rails will modulate the audio signal.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 6th June 2009, 11:03 PM   #19
chrish is offline chrish  Australia
chrish's Avatar
Read this star grounding.
Wiring these things is an art. Once you learn the tricks, as discussed in the link above, you will most likely produce hum-free amps.
Chris
Old 6th June 2009, 11:07 PM   #20
Is it a buzz or mains hum ?
I had a problem with my pre amp with diode switching spikes.
I cured it with 100nF across the decoupling capacitors.
This sounded like a buzz rather than hum despite it being mains frequency.
El84/6bq5/ecc83 + Ef86 = Dc Pp jackinnj Tubes / Valves 10 8th February 2014 07:01 PM
EL84 DC 10Y Project korneluk Tubes / Valves 5 19th May 2008 05:03 AM
Retubing my amp (EL84, ECC81, ECC83) - Tube recommendations? horace Tubes / Valves 18 18th December 2007 01:54 PM
SE EL84 project for my friend akimball442 Tubes / Valves 17 28th June 2007 10:04 PM
OPT Project for EL84 SE Toober Tubes / Valves 23 8th August 2006 04:31 AM
Copyright ©1999-2017 diyAudio
