Help on EL84 / ecc83 SE project -very low volume
Old 7th June 2009, 07:31 AM   #21
mcgaag is offline mcgaag  Netherlands
OK guys. I am going to try the tips you gave my and read some more. Let you know how it turns out.
Thanks,
Rob
Old 7th June 2009, 04:05 PM   #22
Success! No buzz or hum anymore. Problem was the ground connecting from the input. I made a single ground connection for both left and right input channels and that is what i changed. Now both channels have a separated connection to the star ground.
Thanks for the advise. Learned a lot building this amp.
And now i am going to enjoy some music!
Old 7th June 2009, 09:21 PM   #23
tim614 is offline tim614  United States
tim614's Avatar
congrad!!!
any chance for pic?
Old 8th June 2009, 06:49 AM   #24
Here's a pic
Old 8th June 2009, 06:50 AM   #25
And again
Old 8th June 2009, 08:12 AM   #26
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Beautiful job.
Frank
Old 8th June 2009, 08:21 AM   #27
ErikdeBest is offline ErikdeBest  Switzerland
It does indeed look nice! Are you using transformers from Loëwe, the ones that are available from radiotwenthe?
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 8th June 2009, 08:51 AM   #28
The transformers came from radiotwenthe!
Old 8th June 2009, 01:11 PM   #29
tim614's Avatar
sweet!!!
Help on EL84 / ecc83 SE project -very low volumeHide this!Advertise here!
El84/6bq5/ecc83 + Ef86 = Dc Pp jackinnj Tubes / Valves 12 24th May 2017 08:29 PM
EL84 DC 10Y Project korneluk Tubes / Valves 5 19th May 2008 05:03 AM
Retubing my amp (EL84, ECC81, ECC83) - Tube recommendations? horace Tubes / Valves 18 18th December 2007 01:54 PM
SE EL84 project for my friend akimball442 Tubes / Valves 17 28th June 2007 10:04 PM
OPT Project for EL84 SE Toober Tubes / Valves 23 8th August 2006 04:31 AM
Copyright ©1999-2017 diyAudio
