diyAudio Sponsor
Old 5th June 2009, 02:57 PM   #1
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default 4E27 Triode connection SPICE model
I have made a spice model of 4E27 triode connection. The file of
the models for SPICE, SIMetrix and TINA has been uploaded into
my Web as below.
http://ja1cty.servehttp.com/4E27/spice.zip
The file is a ZIPed file including three files for spice, SIMetrix and TINA.
The attached photo is a Ip curve of 4E27 triode connection. It shows
very good linearity and low impedance like 845.
Old 5th June 2009, 06:00 PM   #2
Have you built anything with the triode-wired 4E27?
If so, how did it sound?
Jim
Old 6th June 2009, 12:06 AM   #3
Jim
I've not yet built an amp using 4E27 triode wired. But I did a simulation
using the spice model which I uploaded into my Web.
The simulation schematic is shown in the attached photo. As you can
see, it is SET NO-NFB construction. Operating conditions are as follows:
Ep=700V
Ip=100mA
Vg=-110V
Rl=5Kohm
As a result. THD=2%@20W is obtained. It is remarkably low distortion
within NO-NFB SET amps.
Old 6th June 2009, 12:30 AM   #4
dshortt9's Avatar
I have a few of these and hope to build soon. I was thinking more of the two stage 845 amp using a 6HV5 / 6JD5 at 900 to 1000 volts. There is so much gain to kill in the front end I thought a bit of local feedback would reduce the output impedance of that stage to better drive the 4E27A. 0.7v sensitivity without feedback and lots of swing. There is a thread about this.
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
6AN8 Triode connection + EL 84 PP Tobruk Tubes / Valves 3 2nd May 2007 02:42 AM
WTH -- UL back to triode connection zigzagflux Tubes / Valves 3 6th February 2007 02:59 AM
6V6PP -> 6L6 PP with triode connection. zxx123 Tubes / Valves 4 7th February 2005 06:25 PM
transformers, regulation, triode-connection... metebalci Tubes / Valves 11 20th February 2004 12:01 PM
Page generated in 0.10753 seconds (55.03% PHP - 44.97% MySQL) with 11 queries
