300B driving 845
300B driving 845
Old 12th July 2018, 11:26 AM   #11
gabdx is offline gabdx  Canada
magic sound comes from the amplification stages,
To me I want to listen to the 845 tube distortion, not the 300B + the 845, maybe if you want to have a soup. I prefer to have dinner.
amplificateurslegrand.ca
Old 14th July 2018, 01:29 AM   #12
deafbykhorns is offline deafbykhorns  United States
I sure like my 300b driving a gm70
Old 14th July 2018, 01:04 PM   #13
wredny is offline wredny
What kind of load do you use for 300b, interstage?
Old 15th July 2018, 12:31 PM   #14
Custom Monolith Magnetics interstage. I tried several other methods and this was the most dramatic change. I suspect it would be similar with the 845
Old 15th July 2018, 09:51 PM   #15
You read me like a book. I bought chinese 300b 845 amp as sort of kit and playground. It's capacitor coupled and according to my calculation does very poor job in driving power tube. I was going to go with replacing 7500 ohm resistor with choke but after looking at the prices I figured I might as well go with the 1:1 interstage and give it some room for a2 operation. Can you gents recommend an affordable interstage for testing purpose that would work in my application? 300b supply is 410V.
Old 16th July 2018, 12:42 AM   #16
I used a Hammond for testing but ended up with the monolith magnetics (custom). The Hammond are limited to 25ma but thats not actually a bad thing, distortion is low. I also tried a pair of Silk which you can easily run up to 60-70ma. The monolith was best because the additional inductance. All of these allow some a2 operation My supply was about the same voltage which was ideal. I actually used a 2.5v 40watt 2A3 JJ tube with great results
Old 16th July 2018, 08:41 AM   #17
Thanks a lot! Any expirience with lundahl IS?
Old 16th July 2018, 11:13 AM   #18
Celsius is offline Celsius  Spain
Celsius's Avatar
I have made three different amps with the 211. For me the magic and clear sound has been with 6e5p triode > 2a3 > 211
2a3 have many cheap options with really very good sound, 10y maybe is the best but with less option to buy.
Old 16th July 2018, 12:10 PM   #19
Absolutely!!!
My setup is a 6E5P-JJ2A3-GM70
wredny--
A Lundahl 2753 at 25ma might work (about the same as the hammond IT)
Or you could use a 1671
Both the above would require the cathode resistor be changed (assuming its cathode biased)
A LL1677 is rated for a 300B but its a 1:2 step up
Old 16th July 2018, 12:46 PM   #20
My plan is to try jj2a3 once 300b I got are done.
Lundahls you mentioned are exactly the ones I was considering but I was hoping to get practical feedback, especially in occasional a2 ops. Do you think it's better to stick with higher inductance or current?
Step-up would increase impedance too much...
300B driving 845Hide this!Advertise here!
What are the requirements for driving a 300B? G Tubes / Valves 82 28th March 2012 10:52 AM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 06:59 PM
driving 845 push-pull with a signal from a 300B SE stage Antonio Tucci Tubes / Valves 1 20th February 2007 08:04 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
