6SN7 equivalents in B9A
Old 5th April 2012, 05:27 AM   #51
DualTriode is offline DualTriode  United States
I will save the never and always argument for when it is important, like with my wife. If there is an exception to a True False question the answer is always False.
DIYAUDIO is a good place. there is a world of knowledge and experience, much to be shared and learned. I worked with a Mechanical Engineer from Transilvania Romania. Paul always had a fresh view on how to solve a problem. We argued a lot. I think that those discussions produced better solutions.
In terms of SRPP I agree that there is likely a lot of distortion cancelation. I also agree that the performance is highly dependent on load. If the connected load is not considered in the design the balance between push and pull can be upset and what is thought to be equal and opposite cancelation is not true. This is the exception that makes the answer False.
People love to argue about SRPP.
DT
Old 5th April 2012, 10:06 AM   #52
DF96 is offline DF96  England
Originally Posted by Wavebourn
The main advantage of SRPP is not cancelation. It is dynamic load of bottom tube and using the top one as cathode follower as well, i.e. as the result the bottom tube sees higher load resistance, that is the source of lower distortions.
In a balanced SRPP (i.e. top and bottom identical, no cathode bypass, only lightly loaded) cancellation is a major effect. In an unbalanced SRPP (e.g. bottom cathode bypassed, or mu-follower) there is little cancellation, so the higher load resistance is the main source of lower distortion. In both cases there is further advantage from the reduced output impedance due to the modified CF behaviour of the top valve. Most people use an unbalanced SRPP, so your statement is true for the most common case.
Old 5th April 2012, 04:47 PM   #53
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I did not mean that cancellation do not happen. I mean, 2 devices don't fit like a glove on a hand, so canceling 2'nd order error such a way you add more audible distortions. However, when swing is quite small it is nothing to add, and nothing to cancel.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 5th April 2012, 06:39 PM   #54
Yes, odd-order won't cancel and could be worse (open loop). However, if the stage is within a feedback loop then the reduction in even-order distortion could result in a reduction of odd-order from recycled distortion.
Old 5th April 2012, 07:04 PM   #55
Wavebourn's Avatar
Sure. When linearizing by feedback all possible means of linearization of open loop amp are valid, in terms of linearity. But in no feedback amp the only way to go is to put the tube into most privileged conditions.
Old 6th April 2012, 06:20 AM   #56
I see both cancelation (feedback included) and parameter restriction as design tools.
Speaking of parameter restriction we can increase the load impedance to the extreme of the active load of a mu-follower. When we do this the best we can do is approach the inherent distortion limit imposed by the 3/2ís law of the Ideal triode. There is a limited selection of ideal triodes!
When the SS JFET guys get to this point they add the cancelation of a differential pair.
I scratched the above to post half a day ago. Wavebourn you posted just as I was to pull trigger. I thought the topic was beaten to near death, I guess not.
When we reduce swing to limit distortion one trade off is to reduce the Signal to Noise Raito. Or put another way, say we reduce the output from 20 volts where it popular to test and report distortion data. At 20 volts the higher harmonics are measurable above the grass of the noise floor and within the ability of the test gear to detect. At 2 volts output which is greater than a line amplifier will be used or 10 db down the noise floor is still where it was, the fundamental and harmonics are 10 db less. The higher harmonics are likely lost down in the grass where no one sees or cares.
DT
Old 8th April 2012, 10:53 PM   #57
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
Getting back to the original question, the 6CG7 or 6FQ7 is an excellent B9A replacement for the 6SN7. Apart from plate dissipation, my tests have shown it is about as identical to a 6SN7 as you can get.
Cheers
Ian
Old 27th September 2015, 12:01 AM   #58
carageae is offline carageae  Romania
About the question on the existence or non-existence of ECC80, some could be confused about a single triode EC80, which existed for sure, I have a pair of NOS Valvo, it's in B9A format, with multiple pin connection, I wonder why they did this way, maybe for redundancy? They are 3 pins connected together for the grid...
The data on EC80 therefore excludes the replacement even with socket/PCB modification, it's much higher mu and S than half of an E80CC or the 6SN7/6N8S in discussion. I think it could be an interesting triode, for example for a phone amplifier, also for a small speaker amplifier, what can you say about the linearity of these high mu and high S triodes? The anode power is very tempting - 4W (maybe because of the space being single in the tube).
Last edited by carageae; 27th September 2015 at 12:03 AM. Reason: wrong spelling of existence...I writed first existance...
Old 27th September 2015, 03:03 AM   #59
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
That valve has nothing to do whatsoever with a 6SN7 but this document should answer most of your questions I believe:
http://frank.pocnet.net/sheets/046/e/EC80.pdf
See also :
EC80 as preamp tube.
Frank
Old 27th September 2015, 03:48 PM   #60
EC80 is probably quite unconnected with ECC80 or E80CC. Multiple grid pins are because it is intended for grounded grid RF service, so a low inductance connection to the grid is needed. Not relevant for audio. This sort of triode is intended for either small signal RF gain or for RF oscillation. In either case the sort of linearity we want for audio are not a design aim.
6SN7 equivalents in B9AHide this!Advertise here!
6H30 equivalents woodturner-fran Tubes / Valves 7 20th October 2007 08:00 PM
6F1 and 6P2 Equivalents fmak Tubes / Valves 1 27th September 2005 05:17 AM
MJ15003/04 Equivalents milos_r Solid State 2 2nd April 2004 02:23 PM
Help with Equivalents DieterD Parts 2 1st October 2003 10:58 AM
EQUIVALENTS palesha Solid State 5 28th November 2001 03:07 PM
