6SN7 equivalents in B9A - Page 5 - diyAudio
Old 3rd April 2012, 07:15 PM   #41
DF96 is offline DF96  England
Originally Posted by DualTriode
Often we speak of harmonic cancelation. I prefer the concept of a composite output characteristic curve of the overall circuit.
Same idea, different way of saying it.
I suspect that in a genuine balanced SRPP (i.e. same top and bottom, no cathode bypass) the 12AU7/ECC82 would work quite well as there is some cancellation. For an unbalanced one, including mu follower, there is much less cancellation so you have to rely on the valve's intrinsic linearity - other valves can beat the ECC82.
Old 3rd April 2012, 07:30 PM   #42
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The good thing is, you can cancel 2'nd order distortions decreasing THD. The bad thing is, canceling it you increase distortions of higher order.
The Devil is not so terrible as his math model is!
Old 3rd April 2012, 08:15 PM   #43
Both of the things you mention are not always true. For even harmonics things may not be equal and opposite. Cancelation may not be perfect, perhaps on a good day. For odd harmonics it is not so much canceling but transfer characteristic curves sloping in opposite directions.
Many tube data sheets include “Average Transfer Characteristic” curves. The slope of the curve is gm. From low grid voltage on the left to less negative grid voltage on the right the tube data sheets show increasing slope (gm). The difference between straight line constant slope and the tube data sheet is the source of the 3rd harmonic. Now add a cathode resistor to the average tube in the data sheet, with an increasing cathode resistor value the Transfer Characteristic” curve begins to slope in the opposite direction minimizing the 3rd harmonic as the composite curve approaches a straight line.
So yes, on a good day you can tune a circuit’s composite “Transfer Characteristic” curve to minimize both even and odd harmonics.
Sometimes they do not tell you everything in class.
DT
Old 3rd April 2012, 08:20 PM   #44
miklos is offline miklos  Hungary
miklos's Avatar
"increase distortions of higher order"
I thought you only change the ratio ,low to high order.
miklos
Old 3rd April 2012, 09:41 PM   #45
True, but if signal levels are sufficiently low then higher orders will be low too.
This only works if the sign of the intrinsic 3rd is opposite to the added distortion. Sometimes it works, sometimes it doesn't. For an ideal 3/2 law triode it doesn't work. For an ideal remote-cutoff triode it does work. Real valves are somewhere in between.
Old 4th April 2012, 12:44 AM   #46
Works in SPICE using a 12AU7 Marshall Leach 3/2’s Child’s Law model, worked on the bench with a (made in Canada Amperex 9AU7’s) test Circuit and Audio Tester FFT. Could be because the tested output voltage was at 2 Volts RMS where the 3rd and higher harmonics are tiny to start with.
Page 5 of the linked 12AU7 data sheet (real tube data) shows a positive rate of change of plate current as grid voltage becomes less negative (this curve is without a cathode resistor). Add increasing values of cathode resistor and the rate of change goes from positive to zero and then negative. The added 3rd due to the cathode resistor harmonic is opposite in sign to the original (I believe this is how you put it).
http://www.mif.pg.gda.pl/homepages/f...3/1/12AU7A.pdf
DT
Old 4th April 2012, 09:33 AM   #47
Because of the sign of the second-order distortion, cathode degeneration will always introduce compressive 3rd-order. Thus for 3rd-order cancellation you need intrinsic expansive 3rd-order. The 12AU7A data sheet (on page 5) appears to show compressive 3rd-order for high currents, as the curves approach a straight line, but I accept that they may be expansive at low currents. The risk is that in order to cancel some 3rd-order you end up accepting higher amounts of other orders because you are operating in a non-linear region of the valve characteristic. However, the 12AU7 is unusual in that it is almost square-law in places (this is why it makes a good receiver mixer). Of course in a real circuit there is also the effect of varying mu to complicate things (see page 3 of the linked data sheet).
I worked out some of the maths here, in the context of receiver performance. Note the difference in sign of the third-order term when comparing 3/2 with exponential responses.
I think we can agree that a little cathode degeneration may sometimes reduce 3rd-order. The wrong amount, or at the wrong bias, or with the wrong valve, could make things worse.
Old 4th April 2012, 10:10 AM   #48
I have just thought of an explanation. At low currents, where island effect is present, many valves follow a 5/2 law. This would give expansive 3rd, so a little cathode degeneration will cancel it.
It is possible that a "3/2" model may include some 5/2 at low currents, or achieve the same effect in a different way such as reducing mu.
Old 5th April 2012, 12:24 AM   #49
DF96,
Thanks for sharing the IP3 theory and Maths. Also thanks for sharing your thoughts plus explanation. I like your solution oriented approach to see how the data fits the models.
A couple of years ago I looked for and did not find SPICE models for 5670 and 12B4. I adjusted similar models to match the performance tested on the bench. This worked pretty well above the knee of the curves.
I found a set of plate curves on line for a triode connected 6BQ6, not your ideal 3/2’s law triode. The plan is to tweak the value of the cathode resistor plus varying degrees of cathode resistor bypass by adjusting the value of a resistor placed in series with the bypass capacitor. It will be interesting to see what happens to with the FFT and how clean I can get a few watts of Push-Pull output to be.
Just for fun!
DT
Old 5th April 2012, 01:35 AM   #50
Wavebourn's Avatar
I mentioned "cancellation" by another device with similar curve, like in SRPP example, so it is always true in this case. The main advantage of SRPP is not cancelation. It is dynamic load of bottom tube and using the top one as cathode follower as well, i.e. as the result the bottom tube sees higher load resistance, that is the source of lower distortions.
6H30 equivalents woodturner-fran Tubes / Valves 7 20th October 2007 08:00 PM
6F1 and 6P2 Equivalents fmak Tubes / Valves 1 27th September 2005 05:17 AM
MJ15003/04 Equivalents milos_r Solid State 2 2nd April 2004 02:23 PM
Help with Equivalents DieterD Parts 2 1st October 2003 10:58 AM
EQUIVALENTS palesha Solid State 5 28th November 2001 03:07 PM
Copyright ©1999-2017 diyAudio
