| diyAudio Sponsor | ||
#2 |
Depends on the transformer winding resistance. Use PSUD from duncanamps.com to see if the repetitive peak current is within the tube's rating. With a wimpy transformer, 100 uF would be fine. With a low DCR 9considerably oversize...), 4 uF may be it.
#3 |
Note that the 4 uf is a "typical operation" value not a maximum. In the RCA
receiving tube manual (1950) they have typical capacitance at 10 uF, but then show a circuit for a 25W 6L6 AB1 amp which has a 5U4-G followed by 40 uF. As was noted, the real maximum limit is the instantaneous current, which for this tube is around 2.3 amps, so the real limit depends on the plate-to-plate impedance through the transformer. |
#4 |
Depends on how much current you're pulling, and how much ripple you can stand. Why use a 5U4G anyway? The 5U4GB has a much higher Isurge rating.
#5 | |
Thanks for the enlightening replies.
| Input Capacitor | otherside | Chip Amps | 26 | 20th January 2010 03:32 PM |
| Input capacitor | Triox | Solid State | 31 | 20th January 2010 09:28 AM |
| FS - NOS GE 5U4G ST bottle | t-head | Swap Meet | 2 | 23rd October 2008 04:20 AM |
| 5u4g vs 5u4gb | tenderland | Tubes / Valves | 3 | 28th April 2005 07:58 AM |
| Input Capacitor | Shaz | Chip Amps | 3 | 20th September 2003 06:39 PM |
| Page generated in 0.11868 seconds (55.01% PHP - 44.99% MySQL) with 10 queries |
