Old 2nd June 2009, 09:29 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
So, no reason, just "after"....
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 2nd June 2009, 10:06 PM   #12
McGyver is offline McGyver  Poland
McGyver's Avatar
I heard several times Dynaco ST35 and I liked it very much. It was good enaugh reason for me to do it that way.
Old 2nd June 2009, 10:08 PM   #13
Wavebourn's Avatar
But it had also a local feedback, from an output tranny to screen grids, it is very significant. More deep global feedback could cause instability on high frequencies.
Old 3rd June 2009, 04:00 PM   #14
Banned
Default It will sound better if you triode-strap the EL-84s!
Hi.
Yes, it is a very good approach to bypass the entire tone-control stages as they surely render the sound "horrible". Likewise, I bypassed the entire line+tone-control stages of my 50-year young stock Dynaco PS-2 preamp.
You have done everything right. But you can still make it sound better by converting the PP powerstage from pentode to triode by simply connect the G2 of each EL-84 to its plate with a 100R resistor. I guarantee you will find it sound more transparent, more airy & more musical.
This is what I have done with my 50-year young stock Dynaco ST-70 which sounded "horrible", "fat" & "slow" like what you just described. Like you, I hate vintage sounds.
I triode-strapped the EL-34 Ultra-Linear PP with a more complex Vg2 level shifter, switchable from triode-UL. Yet I've left it triode-strapped mode for ever since day one of its upgrade. I've also reduced the 20dB global loop NFB to 10dB. This offsets somewhat the reduced O/P power after triode convertion.
Listening is believing. Triode sounds so much more musical than pe tode.
c-J
Old 3rd June 2009, 04:30 PM   #15
Wavebourn's Avatar
Sure, if to tie screen grids to anodes less global feedback may be needed.
Old 3rd June 2009, 04:45 PM   #16
McGyver's Avatar
Yes, I LOVE triode sound. But REAL triode, and not triode-strapped pentode. Especially direct heated triodes are magical. I'm using upgraded ukrainian monoblocks based on 6B4G DHT in PSE, and I love it. And Braun amplifier goes to one of my friends. Maybe I'll install triode-pentode switch. No need to drill, becaude there are 3 unused switches on the frontpanel.
Old 4th June 2009, 04:52 AM   #17
WBS is offline WBS  Tibet
Nice work. It is a very clean looking amp.
I would never have guessed it was 50 years old! 50 year old American equipment looks 50 years old.
Old 4th June 2009, 05:22 AM   #18
frugal-phile(tm)
planet10's Avatar
Nice looking amp...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th June 2009, 05:52 AM   #19
Miles Prower's Avatar
Originally posted by Wavebourn
Congratulations!
Everything is fine, except what for did you lower feedback?
May be because he doesn't like that "solid statey" sound you get from too much gNFB?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 4th June 2009, 05:53 AM   #20
Wavebourn's Avatar
My firs DIY amplifier 20 years a go gaborbela Solid State 266 17th May 2013 07:51 PM
quad303 pcb for renovation bigpanda Swap Meet 3 31st October 2008 10:14 AM
Dukane IB3250 ("two-fifty") high current consumption handy Solid State 0 9th August 2004 04:14 PM
Copyright ©1999-2013 diyAudio
