diyAudio Sponsor
Old 1st June 2009, 09:39 PM   #1
Question Philips EL3536
I have two sets of PT/OPT/tubes (EF86, 12AX7, ECL82, EZ80) salvaged from a pair of mono Philips EL3536 RtRs. Any suggestions as to an appropriate SE circuit(s) which would utilize the parts available? I don't have any info on the transformers' parameters...
Old 1st June 2009, 09:49 PM   #2
aardvarkash10's Avatar
Default why reinvent the wheel?
simplify and repackage the circuit. Replace all caps etc, don't bother with the EF86 and the 12ax7 as they are only there to provide gain you no longer need. Keep the existing ECL82. Or, if you want a bit of a fun challenge, RH84 the circuit. Values will have to be modded a bit, and revintage will tell you you are mad, but you have all the bits...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 1st June 2009, 10:09 PM   #3
Default original diagram here
but it shows a slightly different tube compliment to what you have.... http://mb.abovenet.de/tonbandwelt/ph...536/el3536.htm
Old 2nd June 2009, 07:33 PM   #4
Smile Re: original diagram here
Thank you aardvarkash! This, once again, goes to show that this website is a real treasure. For days I had been unsuccessfully searching the net for the original diagram...
I wanted to take a look at the schematic in the first place in order to find an info on the output transformers - 3.5 Ohm speakers were connected and that's what confused me... Since I'm new to tubes and without any diagnostic equipment whatsoever (save for a cheapo digital multimeter), I couldn't measure the primary load...
Further, it turns out the mono RtRs were not EL3536 after all (I was careless enough to throw the decks away without writing down model numbers). They have EL3536 output transformers - WT 511 22, but the power transformers are WT 510 92 and WT 511 13.1 - different numbers but with identical pin layout and both with EZ80...
Another model, though - EL 16B, perfectly matches the parts layout...
And as to the RH EL84 - I've built one and I'm extremely satisfied with it. Hammonds, no PIOs and no tantalums and it still sounds quite nice...
Old 13th December 2011, 02:17 PM   #5
Can anyone post a diagram of an EL16B as I have similar power and output transformers. My transformers are wt 510 92.1 and my out put has the number wt 511 21.
Old 6th January 2012, 05:58 PM   #6
sasha70 is offline sasha70  United Kingdom
Good evening.
This is schematic of output section of EL3536 with WT511 22 transformer.
Could you please comment if anything missing?
Regards.
Old 6th January 2012, 10:29 PM   #7
I think there's missing a capacitor from screen grid (pin 9) to ground.
Best regards!
Old 6th January 2012, 11:34 PM   #8
Tinkerer
...and keep the mustard Philips/Mullard capacitors if you can, guitar amp makers go crazy for them.
Old 7th January 2012, 08:58 AM   #9
mississippi's Avatar
In my "archive" I had a schema.
Here it is.
Old 7th January 2012, 10:38 PM   #10
Thank you for comments and schematic.
I have found this missing capacitor on schematic diagram.
I have found interesting link on how to measure output transformer impedance:
Output Transformer Impedance
Is one EL84 will provide enough gain?
Should I add EL82 (first stage) to this amplifier?
Best regards.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CDM-3 Angelm Digital Source 1 31st March 2003 04:52 PM
Page generated in 0.13712 seconds (60.15% PHP - 39.85% MySQL) with 11 queries
