Oscillation in tube amps
Old 16th May 2018, 12:01 AM   #161
gorgon53 is offline gorgon53  Finland
Originally Posted by DF96 View Post
Adding a small cap in parallel may create exactly the situation it is presumably intended to avoid: a high frequency peak in impedance. Fortunately most electrolytics have sufficiently high HF losses that the peak is not too big, so the unnecessary cap does less harm than it might.
The reality is that because electrolytics are not too great at HF they can damp down the resonance introduced by the extra cap. Normal quality electrolytics don't need bypassing; very low ESR electrolytics must not be bypassed!
Am really glad you pointed that out!
Old 30th June 2018, 03:19 AM   #162
obseedian is offline obseedian  Canada
I was chasing some spurious Barkhausen oscillation (while testing to near clipping at 4 ohms) in my new amps and discovered that the driver signal to the power tubes was not balanced at high frequencies, even though with the power tubes removed the signal was balanced. I haven't tracked down the reason for this, my guess is magnetic coupling from the output transformer since one side of the push-pull quad is closer than the other. This side showed much lower output at the power tube grids than the side farther away from the OPT.
Previously I had reduced the oscillations by fiddling with the Zobel values across the plate/B+ and CFB winding (which are returned to driver cathodes) and feedback capacitors across the feedback resistors but was not able to completely cure it. After I discovered the imbalance, I added 130pF total capacitance across the driver plate resistor that showed more gain and the imbalance disappeared, along with the oscillation.
Oscillation in tube ampsHide this!Advertise here!
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Help Please with tube amps!!!!! bobcat1979 Instruments and Amps 1 28th June 2009 11:29 AM
Tube amps & MP3's jim Tubes / Valves 18 20th February 2008 04:15 AM
Tube Oscillation or Microphonic Question Trout Tubes / Valves 6 29th December 2005 04:18 AM
