#201 |
Yikes, so what happened to cause that Klaus?
I must have missed it when resistors started turning into capacitors... (thanks for playing along BTW)
For security reasons my name is changed daily... |
#202 | |
In the end it's just bad engineering practice.... this kind of death can easily be avoided. Sometimes I've seen an amp going down this way, from POV of the audience and had no chance to help... that' s real bummer! - Klaus |
| Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 6th September 2008 11:35 PM |
| 600 ohm resistor between "+" and "-" of balanced inputs. | skpb | Analog Line Level | 3 | 20th October 2006 12:38 PM |
| Anyone heard of "in-rush" limiter resistor | andy2 | Tubes / Valves | 14 | 31st March 2006 02:39 AM |
