diyAudio Sponsor
Old 31st May 2009, 09:42 PM   #1
flysig is offline flysig  United States
Default Pin numbering, viewed from bottom or top?
Are the pin numbers for tubes as looked at from the bottom or top?
Old 31st May 2009, 09:46 PM   #2
leadbelly's Avatar
http://www.dogstar.dantimax.dk/tubestuf/pinout.htm
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 1st June 2009, 01:04 AM   #3
Thanks, Leadbelly. It would have been less than good to have assumed that the pinout was from the top, like the integrated circuits are!
Old 1st June 2009, 12:21 PM   #4
Sal Brisindi's Avatar
Bottom, you count the pins clockwise.
Sal
Old 1st June 2009, 09:22 PM   #5
richwalters's Avatar
Many IO types have numbers on the tags. Always read from underneath.
No Bottom E? TubeHead Johnny Multi-Way 82 2nd December 2008 02:08 PM
The 'bottom end' PeteMcK Everything Else 0 18th September 2008 07:18 AM
Numbering of National chips Floric Chip Amps 3 18th August 2005 03:13 PM
Tangband serial numbering Jim85IROC Full Range 2 3rd February 2004 04:56 PM
Page generated in 0.08899 seconds (71.49% PHP - 28.51% MySQL) with 11 queries
