| diyAudio Sponsor | ||
Hi all,
I am playing around with a bunch of 0B3 tubes (brand, Electronic Enterprises) and they glow orange. I was under the impression that the 0b3 had a blue/violet glow. The tube seems to be regulating OK. Does anyone know if this particular brand glows orange or do I have a problem with the tube? Cheers, Rob |
#2 |
You don't have problem : the colour of the glow depends on the mixture of gases inside the valve. Most British 85A2s that I've come across glow orange.
#3 |
Thanks Barretter - Then I do have a problem as I am looking for that violet glow!! I achieved this briefly when I removed the shunt resistor and powered up the tube. It flashed blue, popped and then tripped the circuit breaker
Thanks again for the information. Rob |
#4 |
Do you mean series resistor? There should always be a resistor from the raw supply to the anode of the regulator valve. What are you using the 0B3 for? Direct supply of regulated voltage to a circuit or as a voltage reference in a more complicated regulated supply. If you're using it in the first role you can only supply a maximum of 30mA to the circuit from a single 0B3.
#5 |
Barretter is right, you pushed that tube into the arc region of operation which destroyed it. The regulated output voltage is a function of the gas mixture and the geometry of the tube. My understanding (perhaps mistakenly) is that gas mixture and pressure plays the dominant role.
I would be more concerned about the functionality that the tube provides than the color of the glow. All of the 10 or so OB3 I have on hand IIRC are orange glow types.
www.kta-hifi.net |
#6 |
Yes Barretter, the series resistor, sorry. I have about 20 of these tubes and wanted to see just how long the tube would last without the series resistor - not long. I am planning to use it as part of a bias circuit, so current draw wont be a problem.
Hi Kevin, you are correct of course but I was hoping for both functionality and looks. Obviously, the tube mentioned above now has neither. Rob |
#7 |
Well you're going to have to have a minimum current of 5mA otherwise the valve will extinguish. Are you using them to feed screen grids?
#8 |
Yes, will have a power across the output of the tube in order to satisfy the minimum current draw. Interestingly, with respect to these tubes it was my understanding that they could supply a higher current to the circuit as long as the maximum current rating (in this case 30mA) was not exceeded through the tube. Some designs that I have seen show these tubes being used to supply circuits well in excess of the tube current rating, with the series resistor used to limit the current through the tube - I don't think that I have got this wrong but at least for my circuit, it's academic as the bias current is very small.
#9 |
Hmmm, what are you building now Rob
#10 |
I've got some ST shaped sylvania and.. dunno, some other brand. They glow a kind of purpley white.. not as purpley as an 0D3, though.
Then I've got a couple raytheon -GT types, they glow orange (and reg more like 95V rather than 90ish..) |
| Tube glows red hot, blows fuse | damagefactor | Tubes / Valves | 17 | 24th February 2008 07:42 PM |
| Diy Orange guitar amp | thepentium | Tubes / Valves | 7 | 28th November 2005 04:38 AM |
| Orange Capacitors...Please Help | rider | Solid State | 1 | 25th June 2004 05:25 PM |
| Page generated in 0.12021 seconds (74.04% PHP - 25.96% MySQL) with 10 queries |
