Brother can you spare a preamp design?
Old 29th May 2009, 01:46 AM   #1
bereanbill is offline bereanbill  United States
Question Brother can you spare a preamp design?
I'm back again. I am wanting to build an SE amp with a 6SL7 pre, 7408 output, and probably the obligatory 5Y3 rectifier. Anyone know of ant SE amps with a 6SL7 preamp whose design I can purloin ?
Old 29th May 2009, 02:20 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
There are lots of 6SL7 designs out there, from simple cathode followers to SRPP to Aikido
The 7408 is a 6V6 equivalent and there's a thread here in the forum you might be interested in - http://www.diyaudio.com/forums/showthread/t-74176.html
Old 29th May 2009, 10:58 AM   #3
andyjevans is offline andyjevans  United Kingdom
If I read you right you're actually asking for a two stage SE amp design with 6SL7 in the first stage. So not a preamp as such - that would be in a different box.
you could do a search on "two stage amp". you would then find that there are alternatives to the 6SL7 for the first stage. I haven't personally gone that way, but I know that oscillation is your problem with these high transconductance jobbies - the 6SL7 is OK because it's transconductance is lower due to its plate resistance being high.
andy
Old 29th May 2009, 12:10 PM   #4
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
Look at the JE Labs 2A3 design on Angela Instruments website. I've seen this one do very well, and with some careful attention to construction, it can have some interesting options.
cheers,
Douglas
the Tnuctipun will return
Old 29th May 2009, 07:37 PM   #5
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Default Re: Brother can you spare a preamp design?
The 6SL7 is a high gain triode. If you want to use one of these in a preamp (unless you need lots of gain) your only viable choice would be to connect the 6SL7 as a differential, use the 7408 as a cathode follower, set the gain by gNFB, and basically make a glass op-amp.
That'll work quite well, but some folks out there don't like the idea of using gNFB in a pre.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 29th May 2009, 09:51 PM   #6
Johan Potgieter is offline Johan Potgieter  South Africa
Default Re: Re: Brother can you spare a preamp design?
I also think we must first confirm whether Berianbill wants a pre-amplifier, or is just talking about the input part of an S.E. power amplifier.
Some folks don't like the idea of using any NFB. "Like" to me denotes a taste, not showed performance improvement. Good luck to them; it is a free country and their money..
Old 29th May 2009, 09:58 PM   #7
Aah...thank you my good friend, Johan...I was about to clarify that as it seemed some were confused with my question. It is the preamp stage of an SE amp. Basically a 5C1 Champ, but with a 6SL7 in place of the 6SJ7, and cathode biased. I am also adding a single tone control. I will attach a schematic of the 5C1 circut I am starting with. Sorry for the confusion.
Old 29th May 2009, 11:42 PM   #8
Hi - it would help if you don't call parts of an amplifier a "preamp".
What you are describing is the input stage of an amp, not a preamp. I suggest you drop that word unless you are literally talking about a preamp in a seperate box.
andy
Old 29th May 2009, 11:52 PM   #9
Sorry Andy, I thought I did a good job of clarifying that and apologizing in my last post. In actuality, the first half of the dual triode will input the signal and the second half will pre-amp it... sorry if our nomenclature doesn't match.
Brother can you spare a preamp design?Hide this!Advertise here!
Brother-in-law of Zen Fuling Pass Labs 57 25th November 2006 07:12 AM
Little brother of the XA-200 available? (XA-150) MEnsing Pass Labs 17 6th November 2002 06:37 PM
