Russian tube equivelants
Old 29th May 2009, 08:11 PM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
No, 6N1P and 6N2P are not replacements for 12AX7, they are replacements for 6N8S and 6N9S (6SN7 and 6SL7), by initial design, and they were offered in Russia such a way.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 29th May 2009, 10:45 PM   #22
ktuuri is offline ktuuri  Canada
6N1P and 6N2P are 9 pin tubes not octal 8 pin like 6N8S and 6N9S.
6N1P is close to a 6DJ8 but it has a much higher heater current then 6DJ8, 6N1P (600 ma)
Old 29th May 2009, 10:48 PM   #23
Wavebourn's Avatar
You are right; they were designed as miniature replacements for octal tubes, for new equipment development.
Old 29th May 2009, 10:48 PM   #24
bereanbill is offline bereanbill  United States
To DHT112A... Thanks a bunch from a whole lot of people...
Old 30th May 2009, 01:17 AM   #25
DHT112A is offline DHT112A  United States
My pleasure. I found it on the web several years ago but can't remember where or I would have posted the link. Since I did find it on the web anyone who wants is free to post it on their site.
Old 30th May 2009, 02:41 AM   #26
ashok is offline ashok
ashok's Avatar
Thanks DHT112A .
You put it up pretty quick.
Ashok.
AM
Old 30th May 2009, 03:41 AM   #27
motherone is offline motherone  United States
Thanks for posting the PDF, DHT112A!
Old 30th May 2009, 09:20 AM   #28
Arnulf is offline Arnulf  Europe
Funny thing is it matches neither 6SL7 nor *AX7 directly - it has mu of 100 (like 6AX7/12AX7/ECC83), rp close to 6SL7 and somewhat higher Ih, Ia and S than both of those. Being a noval tube it is easy to understand why is is considered to be the replacement for ECC83.
Old 30th May 2009, 12:12 PM   #29
lowtherdream is offline lowtherdream  Canada
lowtherdream's Avatar
This vendor has also a list of equivalent tubes. The russian tubes are at the end of the list p45-49. Lots of details
http://www.vacuum-tube-shop.com/vacuum-tube-shop.pdf
surfing the 2nd harmonic ... @@@@
Old 30th May 2009, 01:30 PM   #30
To Arnulf
The 6H9C is the Russian equivelant to the 6SL7. That's the one I was looking for...watching a couple on Feebay.
Russian tube equivelantsHide this!Advertise here!
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 48 6th June 2013 04:51 PM
