Russian tube equivelants
Old 29th May 2009, 03:15 PM   #11
ashok is offline ashok
ashok's Avatar
You could get a place on www.4shared.com ( free version). Give us the URL and we can all download from there.
AM
Old 29th May 2009, 03:44 PM   #12
DHT112A is offline DHT112A  United States
Ok, here it is
http://www.4shared.com/file/10857196...ube_cross.html
Can't vouch for accuracy.
Old 29th May 2009, 04:19 PM   #13
ethermion is offline ethermion  Antarctica
That's really cool! Well done.
-e
Old 29th May 2009, 04:34 PM   #14
w5jag is offline w5jag  United States
Originally posted by tubelab.com
I have found out that many of those Ebay ads that claim to be "close" "similar" or "equivalent" are pure BS. Some don't even have the same number of pins.
I bought one of those cheap push pull "6AQ5" Chinese amplifiers off Ebay.
I can't say I was real happy to find out that Russian and Chinese "6AQ5" have 9 pins.
Win W5JAG
Old 29th May 2009, 04:54 PM   #15
Thanks for that guide, it should be interesting reading.
Page 4 of the guide lists 6P14 as equivalent to 6BQ5 and 6GK6.
6BQ5 and 6GK6 are pretty similar, but they have materially different pin outs.
Win W5JAG
Old 29th May 2009, 04:54 PM   #16
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
That was the example that I remember. Don't fall for their "WE417A equivalent" either. I am glad to see that neither of these are listed in DHT112's book either. These "equivalents" are likely the work of an over ambitious Ebay seller.
DHT112, thanks it is a good reference to clear the confusion.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 29th May 2009, 05:06 PM   #17
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
I wrote this article some time ago, published in an italian hi-fi magazine:
http://giaime.altervista.org/china.html
I hope you find it useful
Old 29th May 2009, 06:19 PM   #18
Ditto 6N3P, their advertised "equivalent" to 5670 / 2C51. Pinout is completely different.
That little Chinese amp also taught me that incompatibility the hard way.
Win W5JAG
Old 29th May 2009, 07:06 PM   #19
Win W5JAG
I've thought about this a little, and it seems like it may not have been pinout, but some other physical incompatibility between all of the 5670's I own, and the 6N3P sockets in that little amp.
Win W5JAG
Old 29th May 2009, 08:06 PM   #20
Arnulf is offline Arnulf  Europe
Many auction titles that mention "XYZ compatibles" were really meant to say that the tube on sale performs very similar to tube XYZ while not neccessarily having the same pinout. An example of such tube would be 6N2P, a replacement for 6.3V heater wired ECC83/12AX7. It is not fully compatible though (its heater is hardwired in parallel). Some other tubes not only differ in exact pinout but also have different basing (9-pin noval instead of 7-pin mini for example).
So do remember to always check the datasheet
I had a quick look at the abovementioned PDF and it seems to be accurate for all russian tube types I could remember off the top of my head - it doesn't even list said "semi-compatibles" such as 6N2P/ECC83.
Russian tube equivelantsHide this!Advertise here!
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 48 6th June 2013 04:51 PM
