My XPP OTL Headphoneamp
Old 27th May 2009, 08:02 PM   #1
Radioman62 is offline Radioman62  Sweden
Default My XPP OTL Headphoneamp
Hello folks
I have hesitaded a bit to present this building because of all the competing yardsticks and so forth...
But because this is the worlds most visited place for DIY works I had to take a chance
I want to share my design and I also accept all the criticism I can get. Thats the rules, I know.
I Also want to share because I think this is the best forum out there, there is.
This is the shcematic of the amplifier:
This is the schematic of the PSU:
The story of this amp is on one of my homepage sites:
Ove's XPP OTL HeadPhoneAmp
I would be glad for any comments
Cheers// Ove
Old 29th May 2009, 07:44 AM   #2
Default error in the schematic
oops, Im sorry.
I just fixed an error on the PSU schematic. R14 and R15 should go to the bridge instead of the same side of the transformer.
Schematic above is updated, please reload/update your browser.
Cheers// Ove
Old 10th August 2009, 08:21 PM   #3
Default What have I done wrong?
Hi all
It's summer and I have a low profile with electronics.
Anyway, there must be some problem with my languish or my delivery of this project..
Please tell me if my languish are to bold or if you see the advertising for my small "at the side " company... which is in it's infancy ( not cashing any money at all ) or any thing else that I, with my poor english isn't aware of..
I think this is a very good project, at no cost, for an intermediate DIY audio addict to test.
Sincerely // Ove
Old 10th August 2009, 10:28 PM   #4
iko is offline iko  Canada
iko's Avatar
Thank you for sharing, looks nice. Sometimes you have to be patient with this forum, don't be easily discouraged.
Old 11th August 2009, 10:42 AM   #5
Gordy is offline Gordy  United Kingdom
No, nothing wrong with your language!
The project looks interesting. How much power into 30 Ohm 'phones?
Old 11th August 2009, 01:05 PM   #6
Stixx is offline Stixx  Germany
Stixx's Avatar
No problem with your language!
For those who are less educated (which includes me )... can you give a quick rundown of the details/advantages of your schematic ?
Old 11th August 2009, 01:47 PM   #7
Default Quick rundown
Hi all and thanks for looking.
A quicky before you go in deapth reading the links I refer to
It has no output transformer.
The endstage is symmetrically built, X push pull Class A. The more load the less distortion is significant for this amplifier.
The use of common cathode amplifier as the gain/front stage is overlooked. Gives low distortion and very high bandwith.
No global feedback, just some small local feedback at the frontstage, where the smart option to also have a "soundstage control" resides.
Easy to build PSU. Gives very clean stabilized Voltage without any large iron and inductances (big coils).
No special "boutique" components. Instead rather inexpensive and readily available components, including the tubes, allthough the PCC88 is beginning to be more pricey lately.
This amplifier has actually been built exactly as the schematic on my homepage. I'm actually using it in the livingroom to my own delight.
Cheers// Ove
Old 11th August 2009, 01:55 PM   #8
iko's Avatar
Hi, what is the approximate current drawn by each channel?
Old 11th August 2009, 01:55 PM   #9
I havent measured that because I mainly use 60 ohm or 300 ohm. I have a pair of 32 ohm Sennheizers though, that I have used to test with and they give more then enough for any ear
It's also possible to tweak out more current if necessary out of this design, if you allways run it with really low loads. Or parallell more 12B4's to drive even speakers ... in a very inefficient way though
Cheers// Ove
Old 11th August 2009, 02:05 PM   #10
60mA
10ma in each common cathode triodes and 10mA trough the two PCC88 endstage triodes and the last two 12B4's takes 30mA.
Cheers// Ove
My XPP OTL HeadphoneampHide this!Advertise here!
Yet another OPA2134-based headphoneamp Mikael Abdellah Solid State 29 1st August 2005 02:22 PM
headphoneamp with demands.. Mr. Triatic Solid State 10 20th April 2005 10:24 AM
SRPP headphoneamp with E88CC Mr. Triatic Tubes / Valves 13 12th January 2005 11:07 AM
Noise Cancelling Headphoneamp design. Garbz Solid State 0 12th February 2004 07:34 AM
Copyright ©1999-2017 diyAudio
