I have been helping my son tweak his first tube ampifier. It is a SE 6L6. It has a 5U4G tube rectifer in it right now (CLCRC). And I want to swap in a 5AR4 in its place. Give it the slow turn on that comes with the tube. The first cap is less than 60uf, it is a 20uf. So all should be fine, right. Also is the voltage drop going to be greater? If so, can you estimate how much?
- Tubes / Valves
- 5AR4 & 5U4G Rectifier Questions...
