Simple heater question
Is it kosher to lift heaters by hooking the filiment windings CT to a 50v bias tap from another transformer (vs. making a divider from the B+)
Thanks. |
No problem at all. The assumption is you will rectify and produce a stable DC reference. You wouldn't want to just tie it to 50V AC. Also assumes the CT of the winding is essentially circuit common.
Thanks. A simple diode, half wave rectifier would be sufficient? So rectified bias tap to Heater winding CT's to PSU ground bus. Correct?
Exactly
Thanks.
| All times are GMT. The time now is 12:33 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
