Need small SET transformer (12B4)
Old 27th May 2009, 03:57 AM   #1
Pano is offline Pano  United States
Pano's Avatar
Question Need small SET transformer (12B4)
Hi guys - I've been looking at the few 12B4 SET designs here and on the interweb. Can't really find the info I need.
What's a good, small OPT for a rig driven by a little 12B4 triode? All the projects I've seen use OPTs pulled from old consloes. I thought it might be fun to put my 12B4As to good use, if the right OPT is found.
It does not need much power (natch), nor does it need bass. All I want to do is run 16ohm compression drivers on big Altec horns. Minimum x-over would be 320Hz, more likely 500Hz. Active crossover, so no bass worries.
Where can one find such an animal? Any ideas for something off the shelf? Or a common vintage OPT? Thanks for any ideas.
Take the Speaker Voltage Test!
Old 27th May 2009, 04:34 AM   #2
Pano's Avatar
Hmmm... well. I may have answered my own question. If I had been looking in transformer catalogs instead of circuits, I'd have seen that both Hammond and Edcor make iron that might work just fine.
Other suggestions welcome.
Old 27th May 2009, 04:56 AM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
I'd do Edcor over Hammond, but I'd also email Electra-Print and see what Jack can do.
Old 27th May 2009, 04:57 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
What impedance are you looking for?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th May 2009, 05:00 AM   #5
dsavitsk's Avatar
rp's about 1K, so 4K to 5K is probably a good target.
Old 27th May 2009, 05:00 AM   #6
zobsky is offline zobsky  India
zobsky's Avatar
I'm thinking a small line transformer run parafeed could work fine. Parts express has them cheap. I personally used old 5k:8 ohm console pulls for my 12B4 SE amp last year.
In hindsight, consider a direct coupled design, .. I ran into blocking distortion with a (low) B+ of about 220V in my RC coupled design, even running into 97db/w/m full range speakers
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 27th May 2009, 05:05 AM   #7
Pano's Avatar
OK, I've used Edcor stuff and it's not bad at all. Can't beat it for the price!
I dunno Dave. I see SET circuits for this at 5K to 20K.
Tho there are not a lot of circuits floating around - not a common use for this tube. 5K seems kinda low to me.
Sure don't need much power. Suppose I should run the numbers....
EDIT: Zobsky posted while I did. 5K worked for you?
Old 27th May 2009, 05:05 AM   #8
frugal-phile(tm)
planet10's Avatar
The ones i have are 10K:4 OHM IIRC. Real nice German ones.
dave
Old 27th May 2009, 08:41 AM   #9
dsavitsk's Avatar
Default Re: Need small SET transformer (12B4)
It really depends on the amount of power you need. The higher the primary impedance, the lower the output power. A load of 4 to 5x rp is pretty standard as a good balance between power, distortion, and damping.
Edcor is cheap enough to buy different values and see what works
With a 16 ohm load, those will run at 40K. They surely don't have the inductance to do that. Now, since he doesn't need any bass, that might not be an issue, but the power will still be really low.
Old 27th May 2009, 12:59 PM   #10
Pano's Avatar
Got it. OK. Too bad I can't use Dave's nice vintage German iron....
I'll be on the lookout for a small transfo that's about 5K:16R It may end up as Edcor.
Thanks guys!
Need small SET transformer (12B4)Hide this!Advertise here!
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... Mark A. Gulbrandsen Tubes / Valves 801 1st September 2015 04:06 PM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 07:06 PM
