How do these curves look?
Old 27th May 2009, 01:29 AM   #1
astouffer is offline astouffer  United States
astouffer's Avatar
Default How do these curves look?
So I've stumbled upon a DHT with some good initial specs and don't want to say anything and make the price skyrocket. Here is a picture of the plate curves.
Max Vp = 1000
Max Pd = 65 watts
Max Ip = 155 Ma
Max Ig = 25 Ma
Mu = 25
Gm = 6500
Anything stand out that makes this tube not suitable for SE? Plots and loadlines aren't really my thing so I'm wondering how you get a rough idea of the Rp? Thanks.
Old 27th May 2009, 01:44 AM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I think no. Though, PP may work fine with 1KV B+. What G1 voltage is needed for 25 MA current?
The Devil is not so terrible as his math model is!
Old 27th May 2009, 03:27 AM   #3
astouffer's Avatar
Here is the typical operation for class B audio and C RF.
Old 27th May 2009, 03:58 AM   #4
Vargas is offline Vargas  United States
Not bad for a $10.00 dollar tube! Cheers
When you got'em by the ball's their heart's and mind's will follow!
Old 27th May 2009, 04:38 AM   #5
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Anytime anyone with the name VARGAS responds to an inquiry with respect to curves, one's ears [sic] have to perk up, particularly those of us who perused our bachelor-uncle's Esquire in the 1950's!
Alberto, we are unworthy...
Old 27th May 2009, 12:12 PM   #6
Bandersnatch is offline Bandersnatch  United States
hey-hey!!!,
I know those curves anywhere. If you've found a decent supply, would you be so kind as to drop me a note? I need to fill out a quad and have so far found them rather hard to find.
cheers,
Douglas
the Tnuctipun will return
Old 27th May 2009, 03:54 PM   #7
astouffer's Avatar
The replies so far are very interesting. I'm definitely ordering a few now...
Old 27th May 2009, 04:39 PM   #8
Are you looking at the Radio Electric Supply listing? If you are, save them the call...they've got none at all, either A or B version.
cheers,
Douglas
they've got no HY40 either, though it is only 2/3's the HY51
Old 27th May 2009, 06:08 PM   #9
dowdylama is offline dowdylama  United States
Have you experimented with them Douglas?
Jim
Old 27th May 2009, 06:34 PM   #10
Jim
Hi Jim,
Besides lighting them up and confirming the shape and location of the grid=0V line, not yet. I have been considering a MI-9355 sort of amp for them, perhaps even with a clone of the original input TX. 14k a-a with a 1kV B+ should load them nicely. I have not decided on making it a stand-alone or if it should have its driver amp on board.
They're competing with a half-lit 304TL power final...the higher mu is nice, but at the expense of higher plate Z. But if running horns well above cut off, the high output Z( v. the 152TL ) would not be the issue it is with air suspension and bass reflex, eh?
cheers,
Douglas
How do these curves look?Hide this!Advertise here!
DIY U-L curves Bandersnatch Tubes / Valves 10 1st August 2008 12:00 PM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 07:10 PM
Curves, curves, and more curves CarlyBoy Tubes / Valves 5 1st December 2006 11:11 AM
where's the curves? bostonswoop Multi-Way 13 13th March 2006 01:32 AM
Copyright ©1999-2017 diyAudio
