| diyAudio Sponsor | ||
My Hammond 270 has two heater taps, one 5volt and one 6.3volt. Both my 6CA4 and 5687 data says 6.3volts for both. Can I use the 6.3volt tap for both tube heaters or can I use the 5volt tap for one of the tubes?
Thanks Patrick |
#2 |
The 6CA4 = EZ81 has a max 500 Volt between heater and cathode (h neg C pos). So no problem to use the same winding (6,3V) for all tubes. Be sure to have a good ground connection on one side or the centertap of the heater winding.
The 6CA4/EZ81 and almost all 6,3V-heater rectifier tubes with separate heater connections, was actually made to use the same heater winding as the rest of the tubes, despite the difference in cathode voltage. To be sure, you can check your tubes on http://frank.pocnet.net/index.html JohanB |
| 1st Project Heater Wiring | cgrums | Tubes / Valves | 14 | 24th August 2007 07:03 PM |
| A heater wiring DOH! moment?? | maynardg | Tubes / Valves | 4 | 4th March 2007 10:31 AM |
| !2ax7 heater wiring? Series / parallel? | glaznost45 | Tubes / Valves | 1 | 27th February 2006 11:51 AM |
| heater wiring | tenderland | Tubes / Valves | 6 | 2nd March 2005 08:14 PM |
| Page generated in 0.08689 seconds (58.92% PHP - 41.08% MySQL) with 10 queries |
