diyAudio Sponsor
Old 31st May 2009, 11:30 AM   #11
sjh327 is offline sjh327  China
no bad ŁĄ I like
like diy !
http://www.yunwt.net/
Old 1st June 2009, 12:00 PM   #12
Electroshocked's Avatar
This is the schematic..
This is my first board...
There are two ground wires (each one carries the grouped grounds of driver and final stage) wich are connected on the second supply capacitor..
This is my new wiring.. Grounds are connected on the first capacitor (right after rectifier bridge)..
--->Wich one do you think is right?
What do you think about the cathode's circuit? (inside the red line)
Up to now i dont see or hear any difference. Noise remains low.
Testing...
Old 1st June 2009, 12:26 PM   #13
I think you need higher resolution.. sorry!
Old 1st July 2009, 08:20 PM   #14
Testing is going on..
Here are some interesting points about wiring an amp..
http://www.aikenamps.com/StarGround.html
Audio Engineering: Know it all
by Douglas Self, Richard Brice, Ben Duncan, John Linsley Hood, Ian Sinclair, Andrew Singmin, Don Davis,
Eugene Patronis, and John Watkinson
ISBN: 978-1-85617-526-5
Part III - Chapter 13 'Noise and Grounding'
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Reconstruction filter design criteria. Aiace Digital Line Level 2 18th April 2009 09:06 AM
To SRPP or not? duderduderini Tubes / Valves 2 12th March 2007 03:01 PM
Drivers selection criteria. beppe61 Multi-Way 8 19th April 2006 04:18 PM
mu / srpp / or CF? AudioGeek Tubes / Valves 9 24th April 2004 05:48 PM
Page generated in 1.46618 seconds (5.83% PHP - 94.17% MySQL) with 10 queries
