Looks like a promising SE build ?? - diyAudio
Old 22nd May 2009, 12:19 AM   #1
Question Looks like a promising SE build ??
Ok...in my search for a cool higher powered SE build...anyone who's followed my post ... I found this schemo. A couple questions from those of you more knowledgeable then I am. ( That's pretty much EVERYONE...)
1- Where would I insert volume and tone controls...single tone is good...
2- What would the PT need to be rated at ?
3- Any way to eliminate the 2 chokes...or are they pretty commonly available?
As always, thanks in advance...and thanks for all previous help...
Old 22nd May 2009, 12:36 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Something is missing around the grid of EL34.
The Devil is not so terrible as his math model is!
Old 22nd May 2009, 12:59 AM   #3
Something...as in what ? Being a fairly novice hobby-type, I need some help from those more familiar with the design aspect.
BTW...Wavebourn, you've been busy today...
Old 22nd May 2009, 01:12 AM   #4
Question Huh ?
After looking closer at this amp I am very confused. The 845 is a transmitting tube, Right...so what's going on in this amp ? Is the EL34 driving the 845 ??? Where is the rectifier...or power supply for that matter ???
Old 22nd May 2009, 01:16 AM   #5
Wavebourn's Avatar
Such amps are made to work with the minimal power loss, so output resistance of one stage should match input resistance of another one.
This is the essence of such a straightforward approach. However, some global feedback looks odd here, but it won't hurt. It improves a damping factor, and minimizes distortions that grow with power so loud chords would intermodulate less.
Triodes to work need filament power, B+, and a grid bias. Resistor in cathode is for a bias purpose: when current flows through the tube it creates a voltage drop on the resistor, so if the tube's grid is grounded by DC it sees a negative bias in respect to cathode.
Also, this resistor provides a negative feedback by current, so when tubes consumes more current a voltage drop on the cathode bias resistor increases, and vice verse.
Now, can you tell what is missing? Look at the first stage and compare, if you still don't understand after my explanation...
Old 22nd May 2009, 01:16 AM   #6
aardvarkash10's Avatar
Default uuuum, not to belittle you or anything, but
that is one incredibly expensive and (not to put too fine a point on it...) dangerous build for a self-proclaimed novice. 800v operating points are invariably intolerant of unsure hands... Are you sure that you may not be a bit out of your depth here?
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 22nd May 2009, 01:40 AM   #7
If the grid is negative in respect to the cathode, won't that result in cutoff ?
Expensive is the one word that will keep me from trying his design. I have worked on a couple of Musicman guitar amps that have a B= near the 845, but maybe I'll nix this one. I'm looking for something simpler. The search goes on...
Old 22nd May 2009, 02:22 AM   #8
Wavebourn's Avatar
Thank you.
Forget about this amp, it is dangerous! It may kill
Old 22nd May 2009, 02:38 AM   #9
Good advice, that...think I'll take it !!!
BTW...any suggestions for a higher powered SE amp ? Something suitable or adaptable for as aguitar amp?
Old 22nd May 2009, 03:47 AM   #10
Wavebourn's Avatar
Asymmetrical logarithmic amp (one opamp, 3 diodes) driving a very powerful PP amp.
Which of these two kits looks more promising? lurer Multi-Way 0 31st January 2009 07:24 PM
Can I build this? sbcellis Tubes / Valves 6 9th March 2007 01:23 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Copyright 1999-2017 diyAudio
