Old 19th May 2009, 11:29 AM   #1
00940 is offline 00940  Belgium
Default Choke input power supply, capacitor ratings
Hello.
I'm thinking about building a headphones amplifier around the 6n1p and 6n6p as I'm almost done with my dac (something along those lines: http://www.tubecad.com/2006/04/blog0062.htm ). It would require a B+ of near 300V @55ma (idle).
Here are the parts I've already got on hand and can use for the PS of the new amp:
- A 333V CT @65ma B+ transformer, with 6.3V CT @3.5A for the heaters ( I can scavenge it from a broken Heathkit oscilloscope).
- A pair of 3300µF/350V Rifa Peh169
- A pair of 220µF/350V Rifa Peh 169 (I'd rather like however to use those for the output caps of the amplifiers)
- A dozen 20uF/400V MKP caps.
I'm thinking of using a choke input PS, as it would give me in theory 333*0.9= 300V. I'd simply use: xformer - mur860 - choke - 3300uF. The choke could be a Hammond 8H @100mA /259R.
It leaves me with a few question though:
-1- Most hammond chokes I can get have an insulation rating of 400V. It seems borderline in this application. Can/should I use the choke on the ground line ?
-2- What will be the voltage after the choke at startup ? The Rifa are only rated for 350 *1.1= 385V surge. PSUD, with a loading jumping from 3ma at startup (bleeders...) to 56ma after 10s, shows the voltage rising to 330V before falling down to 285V. Are the 350V caps sufficient or not ?
-3- With such a big cap, will the choke sufficient to limit inrush current ? Should I add thermistors ?
-4- What about using a standby switch to ease the startup ? A two pole switch could put in a 47K/3W resistor before the choke and a big diode in the heater supply. (see: http://www.freewebs.com/valvewizard1/standby.html ). Would it invalidate the fears exposed above ?
Thank you for reading this (way too) long post and for any help on this
Ben.
Old 19th May 2009, 12:47 PM   #2
That mur860 is verry likely to fail. The voltage rating is far to low.
Let me illistrate just with a cap input filter. Take a 10v transformer use one diode to rectify it and a cap filter you get 14.1 V less the ~1v lost in the diode or 13.1V then on the other half cycle when the cap is not charging the diode sees -14.1v from the transformer + 13.1v from the charged capacitor for a total of 27.2v across the diode. I believe in your case your
diode rated at 600v will be exposed to ~760v !
Old 19th May 2009, 12:58 PM   #3
Oopsie... you're right of course.
Stupid errors like that happen when one get obsessed over some things and overlook the rest. Thanks for catching it.
Ben.
Old 19th May 2009, 01:45 PM   #4
You also might look at Duncan's power supply designer software.
It indicated and I don't know why that a smaller choke is needed
for your supply something in the 1h to 2h range. By the way the
software is free.
Old 19th May 2009, 03:34 PM   #5
Hum
1 to 2H ? That seems awfully low.
A/ The preamp will idle at 55ma (both channel, 5ma per input stage, 20 ma per output stage, 5ma for bleeders). It's a class A push pull (white cathode follower). If I pull hard on both channel (let's say with low impedance headphones), I could in theory get sustained peaks at 95mA.
This limits me to chokes of at least 100mA.
B/ Rule of thumb to determine the inductance of the choke is output voltage in V / minimum current in mA. Otherwise the voltage output rises. Not a good thing with my 350V caps on the output.
To be safe, let's do the math with one of the output tube failing. Idle consumption goes down to 35ma. Thus we need a choke of about 8H (300/35).
Which brought me to the hammond 157M. The "problem" is that the 157M has high resistance (259). Not a very good thing in our application. It also drops the output voltage at idle at around 285VDC. The 159P is a better choke, at 10H, 125ma and 155R.
I think I'm gonna go for that one. Price difference is only 5€.
All this doesn't tell me if I'm safe with 350VDC caps at the output of the PS...
Ben.
Old 19th May 2009, 04:41 PM   #6
After searching the web, I've finally found a trick on this forum to avoid overvoltage even with an unloaded choke at start-up.
I just need a string of three 100V 5W zeners and a 1k/1w resistor, at the output of the choke. When the output voltage rises over 300V, they'll pull it down. Once the voltage settled under 300V by the idle load of the amplifier, they'll just sit there doing nothing. They'll also offer a nice protection in the case of pulled tubes.
This settles question 2 I guess ?
Ben.
Old 19th May 2009, 10:49 PM   #7
I've been pointed out that this line of Hammond choke is very ill suited to choke input PS and would buzz a lot.
The 193 serie is apparently ok, if oversized. A 193G has 10H, is oversized at 150ma, has a decent resistance of 102R and can suffer 800V. Price is very reasonnable.
Ben.
Old 20th May 2009, 02:47 PM   #8
This thread turns into a nice experience of self-learning and beginner's mistakes.
Let's go back to the questions list:
-1- Choke on the ground side: Bad, bad, bad idea. This raises the CT of the transformer heavily and the choke sees a lot of voltage due to the transients anyway.
Fix: using a Hammond 193 with sufficient isolation rating (800v).
-2- Are 350V caps sufficient: yes but... if the choke is insufficiently loaded, the voltage will jump above V*0.9.
Fix: a string of three 100V/5W zeners + 1K/1W resistor at the output of the choke. If the voltage exceeds 300V, the resistor will start to pull the output voltage down. It shouldn't exceed 330V.
-3- Thermistors: With a choke input PS there seems to be little point.
-4- Standby switch: This also seems unnecessary in this application.
Errors corrected along the way:
- MUR860 are underrated;
- Hammond 157M are unsuitable.
Ben.
Old 21st May 2009, 08:28 PM   #9
DougL is offline DougL  United States
Just a quick note.
I really like the Zener string to protect the Caps.
Thank you for pointing that out.
I will use it in my next design.
I was going to use more current in my bleeder resistors, but your solution is more elegant and causes fewer issues.
As for the thermistors, I am using them anyway. My start-up current is insane without help.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 22nd May 2009, 05:06 PM   #10
Tweeker is offline Tweeker  United States
The choke will see 333VRMS/1155L peak AC current in addition to the DC current.
Hammond 193C or a larger 10H choke if resistance is issue would be my choice. The voltage ratings are conservative (most of Triad's open core chokes quote 1500 VRMS hipot as counterexample.)
Be sure your foil hat has a good low impedance ground.
choke input power supply filter audionut Pass Labs 55 20th May 2013 08:17 PM
Power supply resistors power ratings Nihilist Tubes / Valves 13 31st July 2009 01:47 AM
Choke input P/supply and critical damping kopite Tubes / Valves 3 31st January 2006 03:10 PM
Power supply transformer ratings deskmate88 Chip Amps 4 29th January 2004 05:29 AM
Choke input Power Supply NickC Solid State 4 6th November 2002 07:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
