GE sealants: which to use?
Old 19th May 2009, 04:45 AM   #1
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Default GE sealants: which to use?
I was going to use a sealant to glue some heavy parts on my PCB, but don't know which sealant to use. I bought 3 types of Silicone-II that could find in Home Depot:
GE281
GE284
GE500
I tried to find an information on www.askgesa.com but my Avira warned me that the site contains a virus that tries to infect my computer each time I click on their links.
Which one leaves less of acid? Is one of them safe to use, or no one?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 19th May 2009, 06:36 AM   #2
wrenchone is online now wrenchone  United States
wrenchone's Avatar
All of these you mention appear to evolve ammonia rather than acetic acid. GC sells an electronic grade silicone that is probably available from the usual suspects and would probably work better. I read a report about a servo motor that stopped working when fastened in place with one of the silicones you mentioned, but that may have been due to user stupidity rather than the silicone.
I often use hot melt to glue down large components - shorter drying time. The cream -colored stuff sold by Stanley for wood, etc is gooey enough to stick to most anything, and stays semiflexible, but with good damping factor. I also use it around wire leads for strain relief.
Old 19th May 2009, 07:05 AM   #3
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
I've used "Goop" for years.
When it comes out of the tube, it flows easily and cures to a tight bond. It's also crystal clear.
Frank
Old 19th May 2009, 12:02 PM   #4
Andrewbee is offline Andrewbee  Jamaica
I second the Goop vote. It really is very good and use it all the time. There are several different types E.G. Shoe Goop but I use Plumbers Goop.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 19th May 2009, 12:09 PM   #5
BillEpstein is offline BillEpstein  United States
BillEpstein's Avatar
Goop is contact adhesive and the devil to release for removing components. I use GE Silicone II and have had good results w/o damage to both metal and plastic covered parts over a period of years.
Old 19th May 2009, 12:19 PM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Re: GE sealants: which to use?
GE281
GE284
GE500
Woooaahh, woooaaahhhh -- try 3M 3779 Hot Melt Adhesive -- specifically made for this purpose, i.e. tacking down electronic components in high temperature applications and potting electronic components -- you can get it from digikey, their p/n 3M6422-ND
The product was mentioned on the HP/Agilent Yahoo Group -- you'll need a 5/8 hot-melt applicator/gun not the thing your kids use to glue down macaroni on the mother's day presents.
Old 19th May 2009, 04:22 PM   #7
Jeffrey Davison is offline Jeffrey Davison  United States
Highly recomended for electronics...
Dow Corning 738
Food safe (once cured), and more importantly non-corrocsive.
Some sealants out gas and the gas is corrosive to electronic parts.
So use other sealants with caution.... Dow Corning 738 you will NOT have to worry about.
Jeff Davison
Old 19th May 2009, 10:38 PM   #8
Wavebourn's Avatar
Thank you a lot for your suggestions!
The forum rocks
GE sealants: which to use?Hide this!Advertise here!
