Using James JS-6123HS with EL84 SE is overkilled?
Old 18th May 2009, 05:38 PM   #1
nina is offline nina  United Kingdom
Default Using James JS-6123HS with EL84 SE is overkilled?
I look for a best affordable OPT for EL84 SE (Triode, or run at UL40%), and someone offer me JS-6123HS at ~ US$200.
Look at the spec, this OPT is for 2A3 and 300B. Any one ever use this OPT model with EL84 SE? Will this OPT be overkilled (too good to be used) for EL84 SE?
http://tctubes.com/james-transformers-JS-6123HS.aspx
Thanks.
Old 18th May 2009, 05:59 PM   #2
DougL is offline DougL  United States
Typically, a transformer designed for a 2A3 or 300B will not be usable for an EL84, which has a higher Rp and is best with more primary inductance than a 2A3.
Looking at the link you provided, there are several possible primary options from 2.5K to 5K. the 6BQ5 aka EL84 is listed as a tube this transformer was designed to accommodate.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 18th May 2009, 06:04 PM   #3
Thanks Doug.
I thought that all 3.5K (or 5K) are the same as long as the max current is higher than the running one. Are they?
Using James JS-6123HS with EL84 SE is overkilled?Hide this!Advertise here!
Who knows James 6123HS parameters? Or where to ask HighVividity Tubes / Valves 2 10th June 2009 03:59 PM
james 6123hs totaltech Tubes / Valves 4 30th August 2008 12:21 AM
WTB - James 6123HS Transformers... Guiness Swap Meet 0 10th June 2008 11:44 PM
Fun with James Nixie The Lounge 2 1st March 2007 07:13 PM
Max 300B SE output possible with James 6123HS ? ashok Tubes / Valves 4 17th June 2006 03:07 AM
