| diyAudio Sponsor | ||
Guys, i have a cheap 100k volume pot on my simple se and i need to upgrade it, it is very cheap and nasty, it even squeaks when its turned
What would you go for? 50k or 100k? Log or lineer? Do they have any affect on sound? i guess they do? Thanks guys, Darran. |
#2 |
2 -10 kohm !!
/If the middle pin of 100 k is on down side - low volume - 5-10 kohm, input signal across from the up side - 90 kohm, and there is big resistance for MF and HF for input signal, and small input current doesn't enouht for input capac. of input tube, and there is decrease of HF/ /sorry for bad English!/. |
#3 |
The PEC (Precision Electronic Components) KK series have a pretty good rep soundwise. I have one, and it is of proper construction, you won't break this thing easily. Their website is http://www.precisionelectronics.com/. I bought mine from Digi-key. You 'd probably be best served with a logarithmic potmeter that has a value between 10k and 50k.
#4 |
I was originally going to use the PEC pot mentioned above for my Simple but in a wonderfully boneheaded maneuver I didn't leave quite enough space for it (missed it by >< much) so I ended up using an Alps RK27 pot. Seems to be working just fine. Of course knowing now just how sweet this amp sounds I might have sprung for something a bit nicer. I recently saw that Headamp (a manufacturer of solid state and electrostatic headphone amplifiers) started offering some of the parts that they use for sale to the DIY community. I've used the DACT attenuators that he sells and they are superb and the RCA jacks are also very nice. The parts are listed here and I received my last order from him (RCAs) in a matter of days.
#5 | |
You fitted something better than i have though, looks like a nice pot you did squeeze in though, certainly better than i have at the moment! Thanks for the pointers guys, upgrade is on its way. |
#6 |
Check out familygate on eBay - they still have some 50K and 100K linera taper pots for sale - much better than the RK27 blue dudes......
#7 |
Linear pot = no thanks. I still have an audio/log taper RK40 in my parts drawer, I'm sure I'll use it some day.
#8 |
PM Sent
Steve @ Apex Jr. |
| Simple Volume/Buffer! | amplifierguru | Solid State | 37 | 6th September 2010 06:41 PM |
| Stoked about new volume control for my Simple SE | BillEpstein | Tubes / Valves | 10 | 9th June 2009 07:32 PM |
| Simple sub volume control | Dan2 | Car Audio | 3 | 9th December 2007 03:24 PM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 01:20 PM |
| A Simple Balance/Volume Control | downhere | Digital Source | 6 | 29th November 2001 11:25 PM |
| Page generated in 0.11372 seconds (73.20% PHP - 26.80% MySQL) with 10 queries |
