diyAudio Sponsor
Old 17th May 2009, 08:59 PM   #1
Question Stereo bass problem
Hi guys
Well im new here so say if im doing something wrong.
I have a little problem. Recently finished designing a tube amp, built one monoblock, worked perfectly (for my taste), build a second one, worked the same. But as i connect them both to the power supply at once, bass at lower frequencies dissapears.
Is that a design problem?
A power supply problem?
Or some other issue?
Greatly apreciate your help. Should i post the schematic?
Old 17th May 2009, 09:16 PM   #2
astouffer's Avatar
Its difficult to say without more details but my advice is to poke around with a meter and see how the voltages compare when one amp is connected or when both are connected.
Old 17th May 2009, 09:16 PM   #3
kevinkr's Avatar
More details are needed. Are you sure that your woofers are phased correctly and that you have not swapped connections on the output transformer of one amp relative to the other?
Are these PP amps or SE and do they use global negative feedback or not?
www.kta-hifi.net
Old 18th May 2009, 04:01 PM   #4
So thats why speakers have red and black wires. I rephased one of the speakers and its all fine now.
By the way it's a two SE monoblock amp (6n1p, 6p14p) all made of ex-soviet parts.
Thanks for your help. Got to keep in mind that phasing is essential.
Stereo or 2.1 - Which produces better bass punch? xitronics Solid State 31 2nd August 2009 09:31 PM
Summing a stereo signal to mono for bass... MikeHunt79 Subwoofers 1 16th January 2008 09:48 PM
LM3886 Stereo Amplifier problem Razbi Chip Amps 8 10th October 2006 01:01 PM
dipole stereo bass? xstephanx Subwoofers 63 1st June 2006 12:19 PM
stereo bass query. tade Subwoofers 3 23rd February 2006 04:39 PM
Page generated in 0.06567 seconds (74.21% PHP - 25.79% MySQL) with 10 queries
