diyAudio Sponsor
Old 17th May 2009, 07:24 PM   #1
oshifis is offline oshifis  Hungary
Default SRS-360 East German transmitting tubes
I found two pieces of these babies at a cleanup... Googleing for them:
http://www.radiomuseum.org/tubes/tube_srs360.html
Are they of any good for, say a SE triode amp or something?
Old 17th May 2009, 08:19 PM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
can't find too much on em. apparently equiv with a RS630.
Looks like you'll have to run ludicrous plate voltage, or grid current, or both. gonna need a gigantorg output trafo too...
http://frank.pocnet.net/short/054/3/387.pdf
Old 17th May 2009, 08:21 PM   #3
here's paper for the western equiv, philips TB3/750
http://www.mif.pg.gda.pl/homepages/f.../t/TB3-750.pdf
Old 18th May 2009, 08:19 AM   #4
Good info, thanks a lot. Can they be operated in "starved mode", that is let's say Ua=500V, Ia=100mA in AB1 setting (no grid current)?
Old 18th May 2009, 09:40 PM   #5
Looking at the tb3-750 curves above you can see that at 500V, 100mA is ON the Vg=0 curve so grid current is required to get any output.
On the other hand at 1500-1800V on the plate and a decent 10K opt 20-40W triode SE power is acheivable i A1. if you have a driver that can source some 30 mA grid current you could get some 60-70w in A2 at similar plate voltages.
But please don't even think about it if you're not comfortable with the high voltages involved.
/Olof
I'm not allowed to do magic, union rules...
Old 19th May 2009, 06:18 AM   #6
wrenchone's Avatar
Of course. 5V/14A if a stiff requirement for heating. If you're going that far, you might as well not starve the poor beast at the plate.
High-power amplifier using transmitting tubes Michael Koster Tubes / Valves 39 14th January 2009 11:48 PM
East German Schulz TH315/1 coaxial speaker driver, mint and rare!! welborne Swap Meet 4 9th November 2008 07:07 AM
Any know much abou the East German Schulz TH315 drivers? welborne Multi-Way 2 20th October 2008 11:47 PM
Fountek Electronics South East Asia and Middle East AriesMotor Vendor's Bazaar 9 14th October 2008 03:47 PM
Transmitting Triode Amps gilid Tubes / Valves 39 19th October 2002 01:02 AM
Page generated in 0.07497 seconds (76.97% PHP - 23.03% MySQL) with 11 queries
