Parafeed Circuit
Parafeed Circuit
Old 28th April 2003, 04:55 PM   #1
cdeveza is offline cdeveza  United States
Default Parafeed Circuit
Like to try SE parafeed circuit, anybody knows where I can find a good parafeed circuit I could try?
Thanks,
Alex Deveza
Old 28th April 2003, 05:16 PM   #2
Joel is offline Joel  United States
Joel's Avatar
I just built this, and I like the performance so far.
The choke labled "1.8k ohms" is actually the primary of a Fender spring reverb driver tranny from a Deluxe Reverb reissue. It's probably around 30 Henrys.
Old 29th April 2003, 12:42 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default PARACHUTE...
Any half decent SE amp is a parafeed candidate depending on what OPT type you to use.
Read: can't afford the right OPT for the job? Try parachute technology using a regular PP OPT and prevent DC on it by using a coupling cap, never measure anything anymore and according to some this presents the nec plus ultra...
Ok...just stopped laughing, almost fricking choked.
Fair enough some good SE exist but I can get better results with half the working budget though.
O.K. I'm back to the bunker...
Frank
Old 29th April 2003, 01:29 AM   #4
ultrachrome is offline ultrachrome  United States
Head over to Bottlehead.com. You should be able to glean some information over there. I was under the impression they pioneered parallel feed although they are more into the parallel feed kit business. But you can opt to buy just the construction manual and schematic for their 2A3 and 300B kits.
Also you can check out their Valve magazine which has designs that I would imagine involve parallel feed from time to time.
If nothing else, you might find some links to other sites with PF info.
Old 29th April 2003, 02:30 AM   #5
Joel's Avatar
Originally posted by ultrachrome
Head over to Bottlehead.com... I was under the impression they pioneered parallel feed...
Not unless they were around in the early 1930's.
Old 29th April 2003, 05:21 PM   #6
Thanks Joel,
I am actually looking for a circuit that uses 300B though.
UltraChrome:
Bottlehead does not publish their circuits, would be nice though.
Thanks guys,
Alex Deveza
Old 29th April 2003, 06:00 PM   #7
Joel's Avatar
Originally posted by cdeveza
Thanks Joel,
Ahh. Yes... I can see how the decreased transconductance, increased plate resistance, oddball filament voltage, and enormous pricetag would be appealing...
Old 29th April 2003, 08:51 PM   #8
I did not mean to imply they invented it. But Doc does have some gray hair. Maybe he's older than he looks.
You can buy the schematics/construction manual from them for $15. And you can get good support at the Bottlehead forum which is completely free of and .
Old 29th April 2003, 09:00 PM   #9
Joel,
Well, actually i just happen to have them on hand, not really looking forward to buying one.
Alex
Old 29th April 2003, 10:37 PM   #10
fdegrove's Avatar
Default HAVE A LOOK INTO MY WALLET...
And I suppose it's your right to spend your money as you feel fit.
MC Hammer at work:
Look at your own circuit for a change, silly.
And FWIW, any circuit is meaningless without it's PSU...guess it's going to take you an other fifty years to grasp that?
Not that you'd hear a difference...
Joel, Joel...how much longer? Is it so hard to put your cheapskate ego aside?
Be a sport for a change and we might just reach out and help you too.
Blimey,
Frank
Parafeed CircuitHide this!Advertise here!
2a3 parafeed alexg Tubes / Valves 2 17th November 2007 10:47 AM
to parafeed or not to parafeed that is the question nhuwar Tubes / Valves 63 28th February 2007 12:29 PM
45 into an 845 parafeed circuit rick57 Tubes / Valves 14 12th September 2006 11:36 PM
6V6 Parafeed? G Tubes / Valves 13 8th June 2004 01:05 PM
Parafeed Brett Tubes / Valves 14 7th April 2003 12:53 PM
