| diyAudio Sponsor | ||
anyone got a set of anode voltage/current curves for this little beastie? Yes, I have checked what Frank has available.... Yves, I recall you have worked with this one?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#2 |
#3 |
And so I figured you would have some idea of a useful operating point... or even may have developed some anode V/I curves!
#4 |
Added a usable zone !
Refresh your browser Or, with CCS load as attached below: |
#5 |
enough getting others to design for me!!! Thanks a whole lot Yves.
#6 |
You're welcome
#7 |
It looks to be more linear CCS loaded at 10ma and gives plenty of swing too. What was the reason you chose the 14ma point on your RIAA pre?
#8 |
Good question . . . I dunno !
Perhaps to extract the last half dB gain Anyway, looking at the voltage level delivered by the cartridge, linearity is not the essential issue . . . I think If you plan to build this preamp, keep in mind it must dissipate a lot of calories. Make it larger than mine Yves. |
#9 |
Hello Yvesm,
Do you have schematic for preamp with EC900 / PC900? Thanks, Dragan |
#10 |
| 5-125 UL curves anyone? | dowdylama | Tubes / Valves | 2 | 10th October 2008 11:43 AM |
| DIY U-L curves | Bandersnatch | Tubes / Valves | 10 | 1st August 2008 11:00 AM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| Curves, curves, and more curves | CarlyBoy | Tubes / Valves | 5 | 1st December 2006 10:11 AM |
| where's the curves? | bostonswoop | Multi-Way | 13 | 13th March 2006 12:32 AM |
| Page generated in 0.09853 seconds (75.26% PHP - 24.74% MySQL) with 11 queries |
