| diyAudio Sponsor | ||
#21 | |
the plates turning red, and slighty dials back the bias? |
#22 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#23 |
Hi Anatoly (if I am not mistaken, there must also be an 'i' somewhere in there, but I don't know where...)
Thanks for the explanation! About 170V... My first thought was a rectified and filtered (with a source follower) insulation transformer, but on second thought it would be 'hard' to get 170VDC out of 120VAC. So I don't know... or maybe actual output voltage in the US is closer to 130VAC, which would allow for about 170VDC. Erik I see that you also ask about the garter bias. I think Michael is referring to this.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
#24 | |
Isolation transformers give a nominal voltage under a specified load. Actually, they show 10% more. Now, do you already know what to make an output tranny from? ![]()
#25 |
Most certainly another mains transformer. I did some calculations, but don't know if they are right:
Thinking about it I would say that the maximum peak to peak voltage on the primary can be 340V. This occurs when one plate is at double B+, consequently the other should be at 0V (??). That is about 120V RMS. On the load side: to get 300W into 8R one needs about 50V RMS (50V*50V/8R)... so the ratio primary secondary is about 2.4, and the impedance ratio is 6... the primary impedance would than be ~50 ohms???
#26 |
Yes, it would be about 50 Ohm.
I am going to build a stereo Barracuda prototype on a chassis soon. SY saw it breadboarded, but that time I used LEDs instead of an upper resistor in cathode. Almost no difference, except the radiation frequency.
| What's the weirdest fault you ever fixed? | Circlotron | Everything Else | 72 | 1st August 2009 06:33 PM |
| greatest expert for MK's TQWT sheets here? | Zen Mod | Pass Labs | 0 | 8th June 2006 12:04 AM |
| Which Krell has the greatest sound | Alex helge | Solid State | 5 | 5th April 2006 01:40 AM |
| one of the greatest orchestral recordings ever | dorkus | Music | 15 | 7th February 2003 02:23 PM |
| Page generated in 0.08498 seconds (77.28% PHP - 22.72% MySQL) with 11 queries |
