| diyAudio Sponsor | ||
#11 | |
What happens with screen current? Michael |
#12 | ||
What is garter balancer? Quote:
![]() That thingy drawn gave me 300W with 170V B+ driven by a plain and easy Concertina splitter.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#13 | |
#14 |
"That thingy drawn gave me 300W with 170V B+ driven by a plain and easy Concertina splitter."
Oh, class AB. Yeah, these things work fine in class AB. But the balancer is for class A I think. Maybe the balancer plus the cathode clamp... "One more path in the forest had been named, and a fee paid to protect it from free usage by other people." One more piece of poop legally documented, labeled, and classified! Watch out! A patent used to be a good thing, protecting the poor inventor from being ripped off and exploited by bigger playground bullies. Now the bullies have taken over the patent system and use them as sticks. You have to get patents in your own defense. I say it should go like trademarks, use it or lose it. Except no 100 year extensions like the one they did for Mickey Mouse. |
#15 |
Official Court Jester
boyz , I didn't wrote Monster ...... I wrote Papa ;
that's big difference , in all areas .....
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
#16 |
Honestly, I am glad that the poo...sorry, patent had been granted to Nelson, a smart experimenter.
Could be worse...
#17 |
So in this case it is protecting the inventor from corporate bullies,
and the invention is being used in the inventor's products. Also without a citation it was hard to tell... I'd like to look it up. Michael |
#18 | |
go here : http://www.pat2pdf.org/ look for 5343166
#19 | |
But the only things in common with the circuit I published are it's use of a cascode and a parallel circuit path for bias current. I should explain the circuit operation a bit more. The device above is an active current mirror for the current in the vacuum tube, and optionally provides a fixed elevated cathode bias. The circuit has 1/2 the Rp of the tube alone and 2X the gm for equivalent mu. The objective of the circuit above is to enable the use of high impedance tubes like the 801A with "reasonable" output iron, and resulting in a "reasonable" damping factor. It's basically a substitute for 2 tubes in parallel. I don't know of a circuit just like that one, but it wouldn't surprise me if it had been done in the 1960s. Cheers, Michael |
#20 | |
Also, R7 is needed for better stability of idle current. Now, guess why 170? ![]() Edit: no, it was not Barracuda I was afraid to switch om... It was a Pyramid 7 modified. As I was afraid of, it started oscillating on 300 Khz, and I am going to revert it back...
| What's the weirdest fault you ever fixed? | Circlotron | Everything Else | 72 | 1st August 2009 06:33 PM |
| greatest expert for MK's TQWT sheets here? | Zen Mod | Pass Labs | 0 | 8th June 2006 12:04 AM |
| Which Krell has the greatest sound | Alex helge | Solid State | 5 | 5th April 2006 01:40 AM |
| one of the greatest orchestral recordings ever | dorkus | Music | 15 | 7th February 2003 02:23 PM |
| Page generated in 0.13618 seconds (78.82% PHP - 21.18% MySQL) with 11 queries |
