Single ended amp, EL34, KT88 ideas??
Old 14th May 2009, 12:28 AM   #1
bereanbill is offline bereanbill  United States
Question Single ended amp, EL34, KT88 ideas??
Ok...the next project I'm mulling in my pointy head is an SE amp using EL34 or KT88 outputs and a very simple circut. Anyone have any ideas and/or schematics/plans ? Since my area of interest is mainly musical instrument amplifiers, it would ideally be something designed for or easily adapted for that purpose. I am relative novice-level having rebuilt/overhauled a couple dozen amps and scratch built...with a lot of help from this forum..one screamin' banshee of a mutant Fender circut. I like cathode bias amps for their touch sensitivity...also I would like to easily swap tubes with other compatable types...i.e. KT90, KT100...I appreciate all your suggestions...I have a file full of those so far.
Old 14th May 2009, 12:44 AM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I'll state the obvious one that seems to fit all of those: Tubelab Simple SE.
Old 14th May 2009, 12:48 AM   #3
Default Russ..re Simple SE
That's a PCB amp ? I'd prefer PP ...can I get a schematic and build it from scratch ? Would that be easily adapted to instrument amplifier...i.e. 1 meg input?
Old 14th May 2009, 01:16 AM   #4
torrence is offline torrence  United States
torrence's Avatar
About the most straightforward SE amp design you can write
down is described here:
http://diyaudioprojects.com/Tubes/KT88/
A nice discussion of various modifications can be found here:
http://www.diyaudio.com/forums/showt...hreadid=129647
If you make the cathode bias at least partly adjustable, you can handle
almost any output tube in the 6L6/KT66/KT88 family.
Old 14th May 2009, 01:24 AM   #5
rknize's Avatar
Default Re: Russ..re Simple SE
Yes, it's a PCB amp. You could build one PtP, of course. The schematic and everything is there, but you said simple, so...
Alex's KT88 SE amp on diyaudioproject.com is the one I was planning to build before coming across the SSE. It's a bit simpler than the SSE to boot.
Old 14th May 2009, 01:52 AM   #6
lex's amp looks like a good possibility ! Looks like only i/2 of the preamp tube is being used, no ? That would allow for some artistic license on my part...adding a gain stage...maybe switched as a boost???
Old 14th May 2009, 02:53 AM   #7
torrence's Avatar
It is designed as half of a stereo amp, so the other half of
the preamp tube is used for the second channel. If you are
imagining this for a instrument amp, you could use the other
half to drive a tone stack with no net loss in gain.
Old 14th May 2009, 10:20 AM   #8
Default Torrence
Yeah, I see that now...A tone stack would probably be the more logical use for the second half...I need a way to get some crunch at a reasonable volume. Would an MV be ok with this amp ya think ? Lots of times it squishes these lower powered amps....
Old 14th May 2009, 10:20 PM   #9
maynardg is offline maynardg  United States
I built this one. Very nice sounding.
http://db.audioasylum.com/cgi/m.mpl?...ght=proud+papa
MG
Old 15th May 2009, 06:00 AM   #10
G is offline G  United States
G's Avatar
It sounds like you are looking for a high powered Fender Princeton clone. Try this schematic and instead of the 6V6 use a EL34. Allen Amplifiers has transformer (TO11C) that is perfect for a SE EL34 output. You can find it here:
http://www.allenamps.com/parts.php#transformers
If you want more gain then I would use a additional 6SL7 gain stage and wire it up as a pre and post gain. That will give you all the "crunch" that you want. I had a schematic drawn up for such a beast but I can't seem to find it. I'll keep looking though. You will need to boost the voltage for the output stage also.
Gavin
Single ended amp, EL34, KT88 ideas??Hide this!Advertise here!
Single ended KT88 question overdrajv Tubes / Valves 8 22nd December 2008 10:44 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Single Ended EL34 Amp dsavitsk Tubes / Valves 20 28th January 2007 08:48 PM
Single end 6550 or KT88 amp Ideas please Burnedfingers Tubes / Valves 10 9th March 2003 09:25 PM
Copyright ©1999-2017 diyAudio
